Old 11-25-2018, 12:40 PM
hubbardr1 hubbardr1 is offline
Unhappy Too Deep! Counter sinking the Rudder trailing edge
After getting the rudder ready for priming I went ahead and moved forward to the elevator. The elevator trailing edge wedges went much smoother and much more uniform. So I decided to take a second look at the rudder wedge and I'm worried. I'm pretty sure I overdrilled the rudder trailing edge wedge counter sinks too deep.
The top wedge in these photos is the rudder wedge. Bottom is from an elevator. The rudder depth from top of rivet head to the top of the skin is about double that of the elevator. :/
https://photos.app.goo.gl/wX2FbRErybJMMafu8
You can also see where I pulled the drill press too hard and slightly deformed the wedge edge. I'm worried once riveted, the trailing edge will resemble a missouri road vs something nice flat and and straight.
So what are my options? I've contemplated re-doing the rudder wedge but I've already dimpled the rudder skins. Seems impossible to get the hole alignment right now that its dimpled.
Anyone out there redo the rudder wedge? Successful? Other ideas?
RV-10 Emp Kit ordered at OSH'18
* emp kit complete Jan 2019
* wing kit complete Jan 2020
* fuse kit 75% complete
* finish kit ordered expecting delivery Mar 2021
Happy to provide opinions on what not to do.
N725CA, targeting first flight 2023.
Old 11-25-2018, 01:45 PM
Ralph Inkster Ralph Inkster is offline
Sandwich the wedge between the skins & see if they are too loose, if excessive you would have to get another wedge & try again. You are looking for no gaps between the materials. In your pictures it looks like the countersinks might actually have to be deepened a bit further. Just buff the press marks smooth.
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
Old 11-25-2018, 04:24 PM
!!! Phew. Here I am thinking I went too deep. So you are saying that even the top wedge might not be deep enough? Meaning the bottom wedge surely isnt. Hum. I think I'll get a better dimpled sample skin to test those with and double check. Better to take more off than try to figure out how to add more back in. Thanks Ralph!
Old 11-25-2018, 04:25 PM
Brantel's Avatar
Brantel Brantel is offline
Newish guidance from Vans does not agree with the traditional wisdom on countersinking. It is much more conservative around depth.
The limits are called out in section 5 of the manual.
Just eyeballing the pictures, the deep ones are very likely too deep according to Van’s.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 11-25-2018, 04:30 PM
I'm open to "newish" guidance as well. What is latest?
Old 11-25-2018, 04:43 PM
Brantel's Avatar
Flush - 0.007” section 5 in the manual.
Old 11-25-2018, 05:20 PM
I've read it and missed that. Thanks!
Old 11-25-2018, 06:02 PM
leok leok is offline
Default Correct countersinking depth
When countersinking you have to think through what you are trying to accomplish. The depth is different when placing a rivet only, or when placing a skin and then a rivet.
When a skin has to fit in a countersink, you need to take the thickness of the skin into account. You will have different thicknesses of skin needing to fit into countersinks. Here is how you do it.
Find a small tab of material of the same thickness as the skin at the location. Drill and dimple the tab. You now have a gauge. I make the tab large enough to write down the thickness of material on it. You will end up with several throughout your build.
Using a piece of thick scrap, drill and countersink the scrap until the gauge just fits flush with no gap in the countersunk hole. Now you are ready to countersink the part.
The rivet will fit nicely in the dimple. You need the dimple to fit nicely in the countersink.
Building started Oct 5th 2014, Flying since 1/16/2020
http://www.mykitlog.com/leok
RV Hotel, come by and visit if you're in town
Dues paid 2020
Old 11-25-2018, 07:14 PM
Brantel's Avatar
That's the way I built my RV-7 and many many other airplanes have been built over the years but it does not agree with Van's current advice on the subject. If you do it the old fashioned way, your countersinks will be deeper than what Van's currently recommends.
I was advised by Scott of this new to me recommendation here:
Hi Brian, I noticed on your blog you mentioning your countersink depth of .012-.015" deeper than flush compared to Van's recommended of .007 deeper. The .007 deeper is based on detailed analysis of riveted joints after sectioning them, polishing them, and inspecting under magnification. The error that people make by working to a depth that allows the skin to lay 100% flush is that they forget that on the the cross section shape of the dimple has a small radius where the skin is reformed to make the dimple, but the machine counter sink has a sharp corner. It is the interference of this radius on the sharp corner that you are compensating for in order to get the skin to lay 100 % flush. Doing so results in a gap between the sides of the dimple and the countersink that is clearly visible in the sectioning tests I mentioned. The finished appearance as far as how it looks on the exterior between the two countersink depths is indistinguishable, but the long term integrity could be compromised which is why Van's recommends no more than .007 deeper for dimples into countersinks.
There are a few more post by Scott in the archives that give the detail behind this current recommendation....
Old 11-25-2018, 08:36 PM
TASEsq TASEsq is offline
I've always wondered if instead of countersinking deeper to compensate for the edge radius of the dimple, if you could get a wider, shallower countersink tool and chamfer the top edge off the countersink to account for the radius? (never seen such a tool).
I've definitely seen than a C-Frame makes a sharper dimple than the DRDT2, and these skins sit better in a shallower countersink, in my opinion.
___________
Trent Stewart
Melbourne, Australia
http://www.tasrv14.blogspot.com.au/
