04-03-2007, 06:28 AM
Silt in fuel system
We have a newly aquired RV9a. It is o-320 powered, and so far we have put 20 hours on it with no problem. We have been using AVGAS and MOGAS about 50/50.
We have recently noticed varying levels of particles when the fuel is checked pre flight. It initially looked like sand, but closer inspection shows small brown, gray and white flakes. When rubbed between the fingers, it disolves up in the fuel, so I am guessing that that is how it got there.
I have read about MOGAS giving a brown residue, but can not find any detail.
Have others had similar experiences, or can offer advice.
I feel a switch back to 100% AVGAS is coming!
04-03-2007, 09:36 AM
Fuel Lube
Excess Fuel Lube?
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
04-04-2007, 01:30 PM
Yucky gas
All gas can get contaminated. Get into the routine of flushing out your tanks and cleaning the fuel system before you have problems. If you don't fly your plane, enough, you can keep draining your tanks for the car and you'll always have fresh fuel in your Vans.
04-04-2007, 01:42 PM
huh? avgas in a car? really?
I
i was always under the impression that the lead in avgas would do nasty things to your catalytic converter. unless, of course, you have a '65 mustang without one :-) i'm sure someone will correct me if i'm wrong.
john
john prickett (VAF 449)
manchaca, tx (suburb of austin)
rv-7a finish kit
N337JP (reserved)
04-04-2007, 02:10 PM
"Unleaded only"
Phil, doesn't your car have an "unleaded fuel only" sticker, somewhere ?
Do check!
Regards, PilotTonny.
"Pilottonny"
Tonny Tromp
Lanaken, Belgium (EU)
RV9A, Registration: PH-VAN
ECI-Titan IOX-320 with dual EI, turning a Whirlwind 200RV CS prop.
Sold
The catalytic converter, and your oxygen sensors as well. Burn it in the lawn mower.
