  #11
Old 11-20-2018, 08:12 AM
sjhurlbut sjhurlbut is offline
Default Fine
They?re find under cowl. You?ll still have way more satellites than required. I?ve put them all over the airplane and never had any issues. Usually tracking the max 24 satellites even partially buried. I?ve also had antennas next to each other without affect
Visit and subscribe to Stu's Aircraft Factory on
https://www.youtube.com/channel/UCGQ..._as=subscriber
Steve "Stu"
Cold Lake, Alberta
7A #70015 - C-FZQX - built - sold
7A #71629 - C-FSIS - built - sold across Atlantic
7 #70215 - C-GOJU - flying - sold
7 #70703 - C-GMIY - flying - sold
6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
8 #82842 - C-FSBG - Fastback - built - sold
4 #2723 - building
Old 11-20-2018, 08:32 AM
Dan B Dan B is offline
Default Garmin multiple GPS antenna install min distance
From the Garmin install manual for IFR installations:
"no closer than 12 inches (center to center, 9 inches minimum) from other antennas, including passive antennas such as another GPS antenna or XM antenna. This will minimize the effects of shadowing at 5° elevation angles."
"4. To maintain a constant gain pattern and limit degradation by the windscreen, avoid mounting the antenna closer than 3 inches from the windscreen.
5. For multiple GPS installations, the antennas should not be mounted in a straight line from the front to the rear of the fuselage. Also varying the mounting location will help minimize any aircraft shading by the wings or tail section (in a particular azimuth, when one antenna is blocked the other antenna may have a clear view)."
Dan Burdette
Skyview, ADS-B, Garmin 420W, TT Gemini AP
RV-9A, IO-320, E-Mag
Guthrie-Edmond Rgnl, OK (KGOK)
________
Old 11-20-2018, 10:00 AM
9GT's Avatar
9GT 9GT is offline
I had absolutely wonderful satellite reception with my Garmin G3X antennas mounted on a shelf under the cowling on my RV-10 with the GTN-650 GPS antenna mounted on the cabin cover. I will be putting the G3X antennas again under the cowling of my -9A along with the GTN-650 GPS antenna under there. 6'-6" is the minimum GPS antenna cable length for the 650.
David C.
Howell, MI
Old 12-01-2018, 08:50 PM
MConner MConner is offline
My G3x and 650 antennas almost touch each other and work just fine. No feedback on Dynon but I don?t think these passive antennas are very sensitive to other passive antennas. YMMV
Mark
RV-10
Bought not built
EAA 180
48X
Old 12-02-2018, 07:17 AM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default Inside Right Wingtip
Dynon GPS-2020 and Garmin GA-57X. The top edge of each antenna just barely clears the inside top of the wingtip. No issues with either one.
Dan Langhout
2020 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
665 hours and counting . . . .
Now based at Moontown (3M5)
Old 12-02-2018, 07:30 AM
Walt's Avatar
Walt Walt is offline
Actually GPS antennas are not passive, they have amplifiers and associated electronics in them. Many instances of the old GA35 antennas going bad and taking out nearby GPS's. Mount them next to each other at your own risk, I will never mount an IFR antenna next to another GPS antenna.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 12-02-2018, 08:03 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
I have a Garmin 296 GPS antenna and uAvionix SkyFYX-EXT ADS-B antenna mounted side-by-side on a shelf under the fiberglass cowling on my RV-12. No problems ? excellent GPS reception and dozens of good PAPR reports.
Jim Stricker
EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 622
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father & CFI) - USAAF 1st Lt. Captain B-17H
Old 12-02-2018, 08:23 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
Note that the Dynon GPS antenna doesn't even have a co-ax cable going to it. All of the processing electronics are within the antenna and it has a digital output.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
