  #191
Old 05-24-2020, 09:27 AM
Piper J3's Avatar
Piper J3 Piper J3 is online now
Cycle ignitions approx. 2 minutes after engine start with enrichener (choke) off. Do this at ~2500 RPM. Then check again at 4000 prior to flight with engine warmed up. Also check ignitions in-flight at cruise RPM. Then, when back on the ground, and engine running rough, check ignitions again at idle and at 2500 RPM. Report back findings?
Jim Stricker
EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 618
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father & CFI) - USAAF 1st Lt. Captain B-17H
Old 05-24-2020, 10:22 AM
mcems mcems is offline
Jim
Thanks for the reply
I cant do that its all I can do to keep it running when I can replicate it on the ground.
I little more info here. I was on a test flight yesterday and every thing was smooth and perfect. Then I notice a slight stumble didn't lose and rpms but I noticed the left EGT drop 150 degrees then recovered in seconds. So OK get back on the ground. So I tried to replicate the failure and I got it to fail again this time the right EGT dropped suddenly by 600 degrees. Flooding and shaking like **** . The fuel flow went to 10.5 GPM.
I have been doing mag checks through out all PRM ranges for the last three weeks of this search and all where perfect.
Old 05-24-2020, 11:18 AM
Piper J3's Avatar
I'm re-reading your post #190... You installed new floats, or still running original floats with 1000TT?
Jim Stricker
EAA #499867
Old 05-24-2020, 11:21 AM
i am using new floats
Old 05-24-2020, 11:34 AM
NinerBikes NinerBikes is offline
Sounds like possible debris in fuel lines jamming the fuel shut off valve wide open, that the floats are trying to close down when the float bowl is full.
Check for debris in fuel tanks, lines, carbs, float bowls, to see if there are any partial obstructions.
2020 Dues paid
N72DJ, RV-12, bought flying. A Blessing in disguise. Thank you Double D!
Old 05-24-2020, 09:38 PM
RFSchaller RFSchaller is offline
Brad,
Have you had your carbs overhauled?
Rich
Old 05-25-2020, 07:13 AM
Piper J3's Avatar
Just spit-ball'n here... If you suspect the float is not shutting off the needle valve then perhaps remove the carbs and test on a bench. Not the easiest thing to do. You will need to make hose with banjo fitting to adapt to carb fuel inlet and then enough hose length to make column height for 5psig. It would be very tall column and not practical. So, use shorter hose and method to pressurize - perhaps a hand-bulb. Not best situation, and probably two-man operation, but it would tell you if float valve is not up to the task. You could run this experiment with float bowl on and with float bowl removed. With bowl removed, you can operate needle valve pivot by hand and observe.
Jim Stricker
EAA #499867
Old 05-25-2020, 08:46 AM
Good Idea. Jim
Yesterday I did the the syringe testing method to see how much fuel it would take to make it run out the over flow tube. This method is explained in SB-912-065ul.
I found it only took 20 ML to overflow. So I set the flow level down and retested and got 30 ML. The Rotax SB says the correct range is 23 to 40 ML
Originally I set the float level to spec by measurement's only when I put new valve ,floats and bracket in. So my test yesterday showed the float level to high.
I will be doing some test running to see how that goes.
Old 05-25-2020, 08:50 AM
Maybe being just a little past the acceptable level would explain the intermittent nature of the problem.
Old 05-25-2020, 10:05 AM
Piper J3's Avatar
Yes, I believe that's possible. If, when things start to behave - do the ignition test I suggested.
Jim Stricker
EAA #499867
