  #161
Old 11-04-2019, 06:37 PM
NinerBikes NinerBikes is offline
Originally Posted by Piper J3 View Post
Follow-up to post #132 above...
So, I spent $345 plus shipping for two sets of 861-189 floats and two gaskets. I did the installation this morning and took my digital gram scale with me to measure the old floats, and you guessed it, each pair of floats weighed less than 7 grams. Original floats with 428TT and 100% 93E10. Nuts...
Friend Bob just went through the same thing... Smell of fuel was coming from a non sealing O-Ring on the gas cap, despite the latch and bolts tensioning and compressing/displacing the o ring slightly in the filler neck tube. Replaced the O-Ring, Bob thinks it might be an annual replacement job, adjusted the "squish" of the O-Ring, and the smell of raw fuel is now gone from the cockpit.
It will now take a flat blade screwdriver to move/pry the latch up to remove the fuel cap, from here on out.
Hope this helps someone else.
Old 11-19-2019, 02:47 PM
jeterjim jeterjim is offline
Default heavy floats
This is 2019 isn't it? I started working in my dad's service station 50+years ago. Rebuilt a multitude of carbs and I don't remember sinking floats. In 50+years Bing carbs have gone backwards. This is my 4th set if bad floats in 3 years. That's $600+ in new floats. Come on Rotax! Sorry for the rant.
Old 11-19-2019, 02:54 PM
Piper J3's Avatar
Piper J3 Piper J3 is online now
I'm curious if your latest failed floats are the newest PN 861 189 with shortened brass guide sleeve? I don't know of any 861 189 floats that have failed.
Jim Stricker
EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 618
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father & CFI) - USAAF 1st Lt. Captain B-17H
Old 11-23-2019, 04:50 PM
Yes they are the new floats
Old 11-23-2019, 05:57 PM
And what are you running for fuel? 100LL, Mogas E-10, or ?
Old 11-23-2019, 06:10 PM
Piper J3's Avatar
That's unfortunate. I haven't heard of the new floats failing. A lot of us bought the new floats thinking the shortened brass sleeve would decrease overall weight and add buoyancy. Oh, well...
When your floats sank did you weight them?
Jim Stricker
EAA #499867
Old 11-23-2019, 06:42 PM
tomkk's Avatar
tomkk tomkk is offline
I think my last sinkers were the new ones with the short sleeves ... Mogas with ethanol used exclusively.
Tom
Port Orange, Fl
EAA #51411
RV-12 N121TK ELSA #120845; first flight 06/10/2015; 700 hrs as of 02/2020
RV-12 N918EN ELSA #120995 Eagles Nest Project; first flight 05/18/2019
SPA Panther N26TK; First Flight 03/13/2020
Old 11-23-2019, 08:15 PM
Piper J3's Avatar
And did you weigh them to confirm out of spec?
Jim Stricker
EAA #499867
Old 11-24-2019, 05:57 AM
yes, I did
Old 11-24-2019, 07:21 AM
Piper J3's Avatar
yes, I did
And what did they weigh?
Jim Stricker
EAA #499867
