  #11
Old 11-18-2018, 03:27 PM
msaltzman14 msaltzman14 is offline
Thanks team-
I'm certainly going to sharpie the right spot on the wheel. Also will switch to Airstop at the next changeover.
Thank you!!
Mike Saltzman
Flying -9A N7KR
Old 11-18-2018, 04:29 PM
schaplerrh schaplerrh is offline
I used a paint pen to make the inside of each tire (RV7) with a "T" like shape -- I draw a line across the tire at the bottom of the wheel pants with a short perpendicular line centered on the horizontal line. The short line lets me quickly position the plane when pushing/pulling at the prop, then the horizontal line permits fine tuning the tire position. I then remove the value stem cap as described above and then screw on a 6" flexible value stem extender.
Old 11-18-2018, 06:48 PM
RV8Squaz's Avatar
RV8Squaz RV8Squaz is offline
This is what I did:
Jerry Esquenazi
RV-8 N84JE
Old 11-19-2018, 08:28 AM
Whitman Whitman is offline
Originally Posted by 1001001 View Post
I wonder if this would work?
https://buy.garmin.com/en-US/US/p/131744
Also, wonder if the G3X team has any plans to integrate TPMS?
Also there appear to be a couple of bluetooth TPMS systems out there....
https://www.amazon.com/s/ref=nb_sb_n...bluetooth+tpms
Great idea, who is first to try this?
RV-4, #audiaviator
"Poise under pressure is the single most valuable thing you can have as a pilot. Make mistakes, take corrective action as quickly and calmly as possible and press on."
Old 11-19-2018, 10:17 AM
GatorJim's Avatar
GatorJim GatorJim is offline
From the Garmin website:
Easily Monitor Tire Pressure
Our Tire Pressure Monitor Sensor (TPMS) enables you to monitor your motorcycle?s tire pressure easily and conveniently, as you ride. The system works with up to 4 tires in any configuration (not intended for automotive use). One TPMS sensor is required for each tire (sold separately; metal valve stems only).
Jim Heekin
Orlando, FL
RV-8 QB
Old 11-19-2018, 01:17 PM
Carlos151's Avatar
Carlos151 Carlos151 is offline
Cleveland tool has a neat set to access tire valves.
http://www.cleavelandtool.com/Valve-.../#.W_MYphpMFvI
Drilled holes in the wheel pants that get covered with a snap in metal cap from your local Lowe?s aviation aisle, something like this (different sizes available):
https://www.lowes.com/pd/Hillman-0-3...e-Plug/3013212
Mark the tires with a silver sharpie; when the mark is visible and perpendicular to the ground you?re ready to access each cap.
Karl Richcreek
RV-8
N151TK "La Otra Chica"
Flying as of August 14, 2015
TN26
Old 11-19-2018, 06:23 PM
Smilin' Jack Smilin' Jack is offline
I use a quarter inch long extension with a socket handle to go thru the hole in the wheel pant to unscrew the air cap.
then I use Cleaveland Valve Stem Inflation tool to inflate the tire. It has a built in guage and about a 6 inch inflation stem. all in one tool.
Put the air cap back on and snap in the metal cover and were done in about 10 minutes total for both tires.
I have seen two RV7's with little Cessna access doors... both were done very well.
Jack
Smilin' Jack & Anita Hunt
N507H RV7, KJZP Jasper, GA
EAA690
APRS/ WB4JKY
Retired Corporate Pilot CFI-AI, MEL
CE500, LRJT, HS25, C650, SBJT, CL60
Hunt Aviation, LLC.
Pilot Service, IPC's Biennials.
Comm Glider
