View Poll Results: Which Panel Arrangement?
Steam Gauges Left of EFIS 12 34.29%
Steam Gauges Right of EFIS/Vertical 5 14.29%
Steam Gauges Right of EFIS/Horizontal 18 51.43%
Voters: 35. You may not vote on this poll
Old 11-17-2018, 08:34 PM
Av8torTom's Avatar
Default Panel Layout Choices
I'm getting ready to start cutting holes in my panel and I'd like input on the three panel arrangements below - thanks:
N677AT reserved
Superior XP O-320, 160HP
Old 11-17-2018, 08:50 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
How about the round gauges below the radio and A/P.
XPNDER???
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-17-2018, 09:03 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
I'd give the nod to either #2 or #3 in case you ever have somebody flying from the right seat. I'm currently doing an RV-6A checkout with the airspeed at the far left, and it's doable but then again, I'm a CFI.
And on #2, I'd move the avionics up higher in the panel... less of a transition from outside to avionics.
Best!
Ed
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
Vaccines kept me out of the hospital but COVID still cost me a month of living, all told...
Old 11-17-2018, 09:52 PM
N941WR's Avatar
N941WR N941WR is offline
My first panel almost exactly matches your option 1.
It worked out really well.
However, when I installed the SkyView, I removed all the steam gauges and haven't looked back.
It turns out they are only a backup if the EFIS looses power or burns up as it shares the same pitot and static lines.
I now recommend putting in a Dynon PocketPanel as a backup. It doesn't tie into anything but a power plug and has its own internal battery.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-17-2018, 10:01 PM
bruceh's Avatar
bruceh bruceh is offline
+1 to ditch the steam gauges. Add another screen if you need a backup solution.
Bruce Hill
RV-9A N5771H flown over 900 hours!
APRS Tracking for KJ6YRP and Flying Over the Hills Blog
2021 VAF donator
EAA Tech Counselor, Pre Buys, Build assistance - canopy/tanks/fiberglass/electrical/repairs
Old 11-17-2018, 10:14 PM
Tag Tag is offline
Default Option 3
Agree with Bruce, go all digital, but I?d place the standby display below the radios...
Old 11-17-2018, 10:51 PM
flyinga flyinga is offline
Default Another 3
But no steam.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
Old 11-18-2018, 06:44 AM
terrykohler terrykohler is offline
Default #2
For the reason?s Ed said. Also, you can eventually replace the steam gages with something like a G5 or GRT mini without major surgery on your panel. The second 3-1/8 hole could perhaps be used for an A/P if you want to keep it seperate from your EFIS. Leaving space above the radios allows for future avionics expansion if you eventually want an IFR aircraft (that?s the reason for the G5 or Mini).
Terry, CFI
RV9A N323TP
Old 11-18-2018, 07:19 AM
maniago's Avatar
maniago maniago is offline
If you already have the gauges, Keep the steam! Why? Because you can and it looks cool. It requires no 'trons and you have to run pitot static lines anyway.
#3 is my vote - keeps the radios nice and close, and the EFIS in the middle of your view.....the steam is secondary of course. FWIW, I put my steam above my 12" GRT, so both are in direct line of my FOV, but seems you dont have the room for that.......(I dont have an RV...)
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y
Old 11-18-2018, 08:19 AM
Walt's Avatar
Walt Walt is online now
My suggestion, if you can't swing the G5, 2nd screen and comm 2 leave those out for now with provisions for them later.
Radio stack in this was designed for easy upgrade to GTN650 by removing comm 2 and extending the cutout.
This is a great VFR panel, but trust me, think upgrade path.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags
