Go Back   VAF Forums > Model Specific > RV-14
  #11
Old 11-19-2018, 11:34 AM
didja didja is offline
Originally Posted by TShort View Post
Here's another online resource, not sure if the grip length is enough for your application:
https://www.baysupply.com/2472182/Pr...osed-End-AK42H
Spruce has them too, I don't think the pic represents the actual product:
https://www.aircraftspruce.com/catal...lickkey=266960
These are too big. I would have to drill out the flange holes to 1/8. The van's tech assist rep said that it wouldn't be a big deal to drill these out, but I don't want to risk getting metal shavings into the tank.
I tried to find the 3/32 needed for the existing hole sizes, but just couldn't find any anywhere.......
I will try simply using countersunk blind rivets dipped in lots of proseal, with lots of proseal between the flange and tank skin, and squirting a good amount of pro seal through each hole just to try to cover the rivet as best I can. After all that sets, then try the pressure test again.
Then, and hopefully this wont be the case, if it fails, I can simply open it up through the fuel sending unit and buck in some solid rivets.....
Scott Emerson
RV-14a Kit# 140432
Working on: Wings
Construction log: https://www.youtube.com/channel/UCaZ...Uv2rlQsHtdRmmg
Donation Paid (military)
