  #11
Old 11-17-2018, 06:45 AM
Red Mtn flyer Red Mtn flyer is offline
Default sorry OP
re-read your post - you're already blocking the oil cooler. Later posts tell it right - try a SMALL plate to partially block inlet air, a la Cessna. Outlet flow is better engineering, but inlet is lots easier.
Ben K.
A&P; RLSA - A,G,W/S Falco F-8L
50 yrs of flight and counting
Dues paid 2017 thru 2020
Old 11-17-2018, 08:43 AM
Toobuilder's Avatar
I attached a simple sheet metal extension on the cowl outlet of the Rocket to throttle the area a little. Flat strip of aluminum and 3 nutplates. easy on, easy off.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
