Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 11-14-2018, 07:28 PM
YellowJacket RV9 YellowJacket RV9 is offline
Default SafeFly GPS lateral offset error
Was looking around tonight at my ForeFlight track logs and noticed something odd. Ever since I installed an echouat unit with the GRT SafeFly 2020 GPS, all my track logs have been offset about 100’ roughly ESE of my actual track. It’s only noticeable when overlaid on the ForeFlight taxi and runway diagrams, but it is very consistent. It did not occur when I was using an XGPS150 paired to the iPad.
Initial thought was that I had accidentally programmed a lateral installation offset into the unit, but the direction of that error would change with aircraft heading. My error does not.
Seeing as this is a WAAS unit and supposedly 2020 approved, this amount of error is concerning, but since it is so consistent there’s gotta be a simple cause. I will email GRT tomorrow but was wondering if I am the first to see this.
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 11-25-2018, 12:40 AM
KRviator's Avatar
KRviator KRviator is offline
Originally Posted by YellowJacket RV9 View Post
Was looking around tonight at my ForeFlight track logs and noticed something odd. Ever since I installed an echouat unit with the GRT SafeFly 2020 GPS, all my track logs have been offset about 100? roughly ESE of my actual track. It?s only noticeable when overlaid on the ForeFlight taxi and runway diagrams, but it is very consistent. It did not occur when I was using an XGPS150 paired to the iPad.
Seeing as this is a WAAS unit and supposedly 2020 approved, this amount of error is concerning, but since it is so consistent there?s gotta be a simple cause. I will email GRT tomorrow but was wondering if I am the first to see this.
Given you've said it's a consistent 100' ESE deviation sounds like there is a datum mismatch between your logs, and what ForeFlight is displaying. Is there scope to change the datum in Foreflight for any imported logs?
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
