11-16-2018, 03:38 PM
Air flow performance mixture
Originally Posted by acam37
This FAB is 100% fiberglass. I fabricated a new top piece and on the bottom where the air filter sits is a layer of core mat that is glassed over. This should be maintenance free for a long time. (Still haven’t installed the baffle seal yet)
[IMG]  [/IMG]
fyi
Airflow Performance can provide a mixture control that works in the reverse direction. In other words, you can put the arm above the pivot and eliminate the "notch" in the Filtered Air Box. My Superior kit IO-320 came that way from Eagle Engines.
John Morgensen
RV-9A N946PM 600+ hours since 2013
Nevada/Arizona
11-23-2018, 02:55 PM
Pictures of top plate wear/cracking
These pictures are from top plate #3 or so, taken off around 800 hrs time in service.
The red lines are the cracks. Most of the scratches and the c-clamp marks are post-use. The cracks are quite subtle, and if I weren't sensitized to their likelihood, I almost certainly would not have noticed them. I had to flex the plate while watch a reflection in it in order to distinguish them from simple scratches.
The approximately rectangular areas are where "washers" I made from 1/8" aluminum fasten this to the AFP ring. The underside of these "washers" are well filleted to avoid stress concentrations. Prior to using these, a standard washer would crack the top plate very quickly where the washer made contact.
The underside of the top plate shows how the filter burnishes the aluminum. Some of these burnish marks are deep enough to be easily felt. The filter is quite tightly clamped, but the drubbing that the intake pulses deliver must still move it with every intake cycle.
I'll report back in March as to how the Kevlar on the bottom FAB held up as compared to the previous fiberglass construct.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
11-23-2018, 04:41 PM
On the first RV the top plate cracked twice just like this one. I tried adding an aluminum doubler on the plate (smaller donut covering the mounting holes). It cracked along with the replacement plate. I ended the problem by replacing the aluminum top plate with a piece of 0.032 stainless steel.
No cracking with my modified RV-10 FAB.
On the bottom of the air box I added a piece of 0.032 aluminum to solve the filter ablation problem.
Carl
11-23-2018, 04:57 PM
Gasket
My top plate was cracked and replaced at 500 hours. The new plate is showing signs of cracking after only 75 hours. I talked to Allan at Precision Airmotive and he confirmed that there should be a gasket between the top plate and the servo. Plate #3 will get a gasket.
John Morgensen
Nevada/Arizona
12-10-2018, 10:35 AM
New FAB with split baffle
At 600 hours, I built a new FAB and split the baffle material so that the bottom half is attached to the cowl and the top half is attached to the FAB. Seems to be working well and it makes installing the bottom cowl easier.
For reference, this is a reversed AFP servo with no FAB notch.
John Morgensen
Nevada/Arizona
02-05-2019, 09:40 PM
So, here's an airbox question.
The O-320 airbox has a plate that bolts to the bottom of the filter. Bolts go up through the filter and are secured by nuts at the top of the airbox. There is a quarter inch (or more) between the filter/plate/bolt heads and the airbox itself, so there is never any rubbing of the filter on the airbox.
Why weren't the -360 and -540 airboxes designed the same way? It seems like the airboxes for the larger engines are much more problematic and (too often) allow the filter to wear through the bottom of the airbox.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
02-06-2019, 07:11 AM
I ran the FM200 vertical draft for over 1000 hrs on my 7A, never cracked the airbox mount plate.
I do have the front supported by the 'old' carb heat scat tube setup, left it there intentionally to support the front of the box even though its no longer needed.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
02-06-2019, 07:39 PM
I made a 0.125 top plate for the FAB (IO-320-D1A vertical induction) and it's holding up well at 320 hours. I put a gasket between it and the fuel servo, and Pro-Sealed a 0.063 plate inside the bottom of the FAB that contacts the entire lower seal of the filter. No additional support on the nose of the FAB.
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
02-08-2019, 11:26 AM
When I built I also made an all aluminum airbox. There were some post on VAF that showed guys pulling cowling only to discover their airboxs cracked or laying in the bottom of the cowling.
Paul Gray
Foley, Alabama
N729PG..... 450+ hrs
RV 7A, Lycoming 0 320 D1A, Sensenich FP propeller
pilotforfun2001@yahoo.com
VAF supporter $$$
02-09-2019, 12:04 PM
Here's an old short article I wrote for the RVator's Log (March 2014):
A very common issue with the Filtered Air Box mounting is cracking of the mounting plate, which often happens at the first condition inspection. There is a two-fold method to avoid this frustration. First, make a duplicate FAB mounting plate out of 6061-T6 aluminum, which is far less brittle than 2024-T3. I have never seen this piece crack when using the T6 al- loy. Second, make a ?gasket? out of cork material from your local auto store. At Tom Berge?s suggestion, I used some 1/8 material, which seems to cushion the vibration between the engine and the mounting plate. At 250 hours, no cracks!
(Note.... I now have 730 hours and no cracks)
Doug Weiler
Hudson, WI
president, Twin Cities RV Builders Group
RV-4, sold
RV-7 completed and flying N722DW, 840 hours
Based Lake Elmo, MN (21D)
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
