Go Back   VAF Forums > Model Specific > RV-4
  #11
Old 11-15-2018, 10:52 AM
acam37's Avatar
acam37 acam37 is offline
How efficient is the NACA duct on the right side? I read somewhere that it doesn?t work as good because of prop rotation and airflow down the fuselage? If there?s not any difference then I can move my vent to the right side without any interference on the inside. Then just use one duct for both panel eyeball vents
Arlie Conner (A&P)
RV-4 (N124TT) Sold
RV-8 (N269CP) Sold
RV-4 (N684ML) completed 3-17-19
KOCH Nacogdoches
Old 11-15-2018, 11:31 AM
fixnflyguy fixnflyguy is offline
Default I have one on both sides
I put the NACA vents on both sides of my-4, just below the cheeks, and both produce strong airflow. I don't notice a difference between the 2. Because the panel space is limited on the -4 and I didn't want them at my knees, I installed the eyeball directly to the back of the NACA vent with no flex ducting.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 11-15-2018, 02:32 PM
AX-O's Avatar
AX-O AX-O is offline
I have one on both sides. I get similar airflow out of both vents. Not sure where this wife tale keeps coming from. If i had to do it again, I would only use one NACA intake and split the air into 2 vents.
Those NACA vents look great on the cheeks.
Not sure the NACA vent is working as the design intends in those locations. we may be able to get away with a smaller hole there due to the angle of the cheek.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 11-15-2018, 04:10 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default What size vent and source ?
Good info from all,thanks much. Vans website is hard to find a suitable specimen and ACS is also limited. What size and where to buy ??
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 11-17-2018, 06:33 PM
smokyray's Avatar
smokyray smokyray is offline
Default Finally, air....
Larry,
Cheez just sent me this photo, he's been down unda, that's why it took awhile. Purchase the Van's SV-1 Vent Kit and download cutting template online. I glued mine to the inner skin with HySol. Still stuck after 20+years!
Cheez' RV4 is one of the nicest ones out there BTW...
V/R
Smokey
Old 11-18-2018, 06:47 AM
rv4ross rv4ross is offline
Larry,
I used this part from Van?s.
Part Number = VENT SV-1
Price = $6.25
Ross Scroggs
