Old 11-12-2018, 08:41 AM
kgrasse kgrasse is offline
Question Fuel pump fittings
I need help plumbing the Lycoming mechanical fuel pump. My questions are, #1, how are the fittings tightened down (not the fuel line)? Tighten the fittings and then torque the jam nut/O ring, or torque on both? #2, before I order the wrong part, what size is the fitting that attaches to the overboard vent?
-7 up and flying
Dues paid
Old 11-12-2018, 08:48 AM
RV6_flyer's Avatar
Screw the fitting in to get the angle the hose attaches correctly oriented then tighten the jam nut with the o-ring.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 11-12-2018, 10:26 AM
lr172 lr172 is offline
You can use a wrench to hold the fitting in position while you tighten the nut, if desired.
The overflow is 1/8" NPT, so fitting of your choice.
Larry
Old 11-12-2018, 06:11 PM
Thank you!
-7 up and flying
Dues paid
