Old 11-10-2018, 06:21 PM
wfinnell wfinnell is offline
Default How to polish exhaust
I would like to polish my exhaust pipes like the ones in the Kitplanes link below. I remember someone saying something about using the back of emery cloth, or something like that... at least I think I do.
My question, do you polish exhaust pipes in the normal way, or is there a special trick.
I know, I know, this is considered a waste of time by many, but I enjoy polishing metal.
https://newsline.kitplanes.com/2015/07/22/rv-eye-candy/
Thanks in advance,
Bill Finnell
RV-8 Fuselage
Tucson AZ
Old 11-10-2018, 06:37 PM
NYTOM NYTOM is offline
Default A alternative method.
I started to polish mine using a 8? sewn cloth buffing wheel on a large bench type grinder motor. I used black emery coumpound in a stick form applied to the wheel. Takes forever to get a mirror finish and throws a black lint like substance everywhere. Very messy. I found it much easier to just rough up the surface with a extremely course drill mounted 3M pad. The type used to remove paint. Makes it nice and shiny ( not mirror) very quickly and touching up after it discolors from heat cycles is very easy. IMHO.
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360 FP
Old 11-10-2018, 06:54 PM
FLTENG FLTENG is offline
I have to ask.............WHY??
Cheers, Hugh
CF-HGD
Old 11-10-2018, 07:21 PM
Toobuilder's Avatar
Because details are important.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 11-10-2018, 07:36 PM
Mark33's Avatar
Mark33 Mark33 is offline
Default Polished firewall
"Kind of" on the same topic,...what's the recommended procedure for polishing the firewall? I don't necessarily want a mirror finish but I'd sure like for it to be shinier than the stock dull finish.
Mark
Old 11-10-2018, 07:50 PM
j-red j-red is offline
Consider a jeweled finish for the firewall. Seen it done before. Pretty easy in that it just takes a circular wire brush or other abrasive in a drill to turn it while contacting the surface at consistent intervals.
Rebuilt RV-6A N94CR
RV-8 N803DR completed, flying.
Old 11-11-2018, 08:18 AM
I?ve seen a small 3M pad on a arbor chucked into a drill press and a used to polish a RV4 firewall before it was riveted in. Just draw your desired pattern with a sharpie on the firewall and go for it. Set up takes longer than the actual polishing. Only takes a few seconds of pressure on the pad to get the affect. It?s those little extra details that sets a plane apart from the herd.
Tom Norwood
TMX-O360 FP
Old 11-11-2018, 10:06 AM
Infidel's Avatar
Infidel Infidel is offline
Use Chrome polish, the same as one would use on Mag wheels. Start w/polish on a 3M abrasive pad, then transition to a softer terry towel.
Eezy Peezy.
