Old 11-10-2018, 09:50 AM
pilot28906 pilot28906 is offline
Default Spinner Rear Bulkhead
Do the bolt holes in the spinner rear bulkhead (S-602-1) have to be drilled out to 3/4" to fit over the lugs on the prop extension? I am assuming so but wanted to make sure before i opened them up.
John Johnson
Murphy, NC
RV7
Old 11-10-2018, 07:41 PM
Robin8er Robin8er is offline
I had to drill mine to fit. But just be careful and make sure you are drilling to the correct diameter. Make sure its clamped down good when you drill it.
RV-8 N695RA flying
Working on an RV-4
Born to fly, forced to work
