Old 11-10-2018, 09:29 AM
David Carter David Carter is offline
Default Tach Time RPM value on Van's mechanical tach?
Hi,
I have installed a JPI EDM-350 engine monitor with a magneto RPM pickup.
There is a calibration setting "average cruise RPM" with a description "Average cruise is based on a percentage of RPM redline. A one to one ratio for TACH TIME is achieved at this setting."
I have it set at the default value of 2400 RPM. I left the mechanical tach in for now to compare the readings. After about 2 hours tach time, the difference between the two is 0.1 hours.
Does anyone know at what RPM Van's mechanical tach reads one-to-one with wall clock time? Or is there another source for a "better" value for this on a Superior O-360?
David
David
RV-7A Slider N87BP (bought flying in 2018)
Superior XP-IO-360
AFP Fuel Injection & Dual SDS CPI-2 ignition
KLZU - Lawrenceville, GA
2020 Dues Paid
