Old 11-09-2018, 08:17 AM
albertaflyer albertaflyer is offline
Default Running electrical and fuel lines together
Is it ok to run electrical lines tied to fuel lines for a wing fuel transfer pump and if so, what is considered the proper way to do it?
thanks,
Tony
Old 11-09-2018, 08:38 AM
terrye terrye is offline
You should consult FAA AC 43.13 for questions like this.
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
Old 11-09-2018, 08:44 AM
Mel's Avatar
Mel Mel is offline
In a word, NO! Electrical and fuel lines need to be run separately.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-09-2018, 08:54 AM
The electrical lines are run in a conduit then exit and loop around to the fuel pump, which happens to be along the same route as the fuel line. They are currently zip tied to the fuel line. Just wanted to confirm what was acceptable.
Thanks for the quick response.
Tony
Old 11-10-2018, 03:39 AM
maniago's Avatar
maniago maniago is offline
AC 43.131B 8-31 Fuel Lines and Fittings, para B "Routing". I cant copy and paste the section cause its a .pdf, but you can search for it if need be. You can run them together, but read the para for clarification on exactly how that is to be done. For sure, separation is the preferred method.
Additionally, Section 8 Wiring Installation, 11-96, para W (change 1) has a slightly more expansive and perhaps somewhat contradictory take on it as noted with the words "where practical".
Section 11-126 Flammable fluids and gases has similar wording as 11-96 in Section 8, but includes a picture of a wire bundle and fuel line together....
There maybe others, but thats what I found in a quick search. I did this as I'm also currently running wing wires and have tip tanks with fuel lines running in similar areas, so it was a good question that you asked......thanks.
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Old 11-10-2018, 11:26 AM
Mich48041 Mich48041 is offline
Quote from AC 43.131B chapter 8 paragraph 31 page 8-19
b. Routing. Make sure that the line does
not chafe against control cables, airframe
structure, etc., or come in contact with electrical
wiring or conduit. Where physical separation
of the fuel lines from electrical wiring or
conduit is impracticable, locate the fuel line
below the wiring and clamp it securely to the
airframe structure. In no case should wiring be
supported by the fuel line
Joe Gores
RV-12 Flying
