Old 11-08-2018, 09:09 AM
dabney dabney is offline
Default Flight training in ELSA. IS IT ALLOWED?
I am on the verge of buying a RV12 ELSA for the purpose of teaching my daughter to fly. I am a sport pilot instructor.
Yesterday I read that the FAA has, or is about to, release a NPRM to allow flight training in ELSA .
1. Can I give my daughter flight training leading to her Sport Pilot airplane certificate?
2. If so, are there DPE?s who will give the check ride in an ELSA?
Paid for 2021 and well worth it!
Best return on investment I make all year....
US Army 1st Cavalry Division OH-58 AO
LAPD helicopter pilot, retired
RV6A sold
RV12 (non-builder)
Old 11-08-2018, 10:42 AM
rocketman1988 rocketman1988 is offline
Default Not sure it is what you want...
"...The FAA has released a notice of proposed rulemaking (NPRM) that supports a crucial EAA ultralight and sport pilot training initiative. The NPRM amends 14 CFR 91.319(e)(2) to allow compensated flight training in experimental light-sport aircraft (E-LSA) in certain circumstances under a letter of deviation authority (LODA).
EAA has long sought an expansion to the FAA?s LODA policy that will allow for more types of training in experimental aircraft, including limited primary training in certain ?low mass, high-drag? types to address a lack of available aircraft for sport pilot and ultralight training. The reform to the E-LSA rule will allow a small number of ?grandfathered? operators to continue to provide training, and reverses the removal of E-LSAs from the training fleet, as long as the training is conducted under specific, approved conditions.
?The successful publication of this rule and the accompanying policy change will create new opportunities in ultralight and sport pilot training,? said Tom Charpentier, EAA government relations director. ?We see ultralights and light-sport aircraft as an increasingly important pathway into aviation, and we are working with the FAA in a variety of ways to remove unnecessary barriers to access. This is one small but important step in that overall process.?
The revised LODA policy will also improve access to amateur-built aircraft transition training. EAA is working with the FAA to publish the policy as soon as practical, possibly in advance of the final E-LSA training rule. Those wishing to comment on the NPRM may do so before November 23..."
Bob
Aerospace Engineer '88
RV-10
N464RL
Dues+ Paid 2020,...Thanks DR+
Old 11-08-2018, 11:02 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Default My $0.02
As I understand it, if it is your plane, and no payment is offered, you should be good to go.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-08-2018, 11:56 AM
rvbuilder2002's Avatar
More specifically.... As long as there is no compensation to you for use of the airplane, there is no problem in doing what you want to do. Specific limitations are spelled out in the operating limitations that are part of the 8130-7 (airworthiness certificate) for E-LSA aircraft.
You could receive compensation as a flight instructor while giving training though.
The NPRM you mentioned is related to compensation for use of the aircraft (charging rental fees), and more specifically, for aircraft types were there are no SLSA examples for flight schools to use. An example would be 2 seat ultralights that were originally converted to ELSA's during the transition period, so that they were legal aircraft under the new rules.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 11-08-2018, 12:09 PM
Jimd Jimd is offline
Default Sort of...?
Related to this topic a bit...
Has there been a change to the single pilot restriction during phase I testing that allows two pilots? What if the second pilot is there for dual instruction? I had a query to provide flight training in an owner provided Airplane but it has NOT flown yet.
Sorry for borrowing your thread...
Jim
RV-6
RV-10 tail kit 50%
(When do I get to measure something?)
"Flying north of the Arctic Circle and back - several thousand dollars,
Doing it in an RV you built yourself - PRICELESS!"
Old 11-08-2018, 12:37 PM
Mel's Avatar
Mel Mel is offline
Jim
Read FAA AC 90-116 carefully. It defines addition pilots who can be on board during phase I. It is restrictive. Flight training is NOT a part of Phase I. This AC also must be listed within the operating limitations for the aircraft.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-08-2018, 06:55 PM
Default Sport pilot checkride in ELSA
Has anybody encountered a problem finding a DPE to perform a sport pilot initial checkride in a RV12?
RV6A sold
RV12 (non-builder)
Old 11-08-2018, 07:53 PM
BlndRvtr BlndRvtr is offline
Default DPE and RV12
The only issue I know of regarding a DPE giving a flight check in an RV12 was that the FSDO having jurisdiction over the DPE required the DPE to have 5 hrs. PIC in the make and model of each experimental aircraft they were going to use for a flight check.
Anyone else run into such a stipulation?
George
Old 11-08-2018, 08:11 PM
DaleB's Avatar
DaleB DaleB is offline
George
Yes. I flew with the DPE to get his five hours in, so he could give my co-owner his Sport Pilot check ride in the same airplane. Fortunately he didn't need dual instruction... just stick time. In fact, he taught me how to fly from the right seat, and I'm toying with the idea of becoming a Sport Pilot CFI. Little to no practical use for that right now, but if I time it right maybe I can do that to stand in for my next flight review.
Dale
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 11-08-2018, 09:56 PM
hook hook is offline
I had a guy do his initial CFI (Subpart-H) in my S-LSA RV-12.
RV-12 Owner & Flight School Operator
CFI/CFII/MEI
LSRM-A
chris@flygcaa.com
