Old 11-05-2018, 07:38 PM
mikemalone mikemalone is offline
Default Odyssey PC680 Connections
When I purchase a new Odyssey PC680 battery, will it come with everything to connect it up, except, of course, for the battery leads? What size of terminal would be needed (lead connector hole size) to attach 2 AWG cables to this battery?
Mike Malone
RV7 Builder
Worcestershire, UK
Paid-Up 2020
Old 11-05-2018, 07:53 PM
RV7A Flyer's Avatar
Yep. And I believe the terminals are M6 bolts, from the diagrams I just looked at a couple of days ago (the manual that comes with the battery). Comes with all the nuts and whatnot you'll need.
2019 Dues paid!
Old 11-05-2018, 07:54 PM
gasman gasman is offline
ODYSSEY Powersport Battery Model PC680
(internal threaded brass terminals, M6 SS bolts, and L bracket adapter)
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 11-05-2018, 09:03 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
I'm wiring the fat FWF cables right now too. If your going tefzel wires then 2 awg terminal with 1/4" ring. If using welding cable (like I did) use 4 awg terminal with 1/4" ring. (Note: The welding cable is smaller in diameter hence the smaller cable terminal.)
Another option is you could also go with the adapters similar to these
using the 5/16" ring terminals to be more "consistent" in ring size.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
