Old 11-04-2018, 10:39 AM
Strikefinder's Avatar
Strikefinder Strikefinder is offline
Default Elevator Trailing Edge Dent (Oops)
Hi folks,
Well, a momentary lack of sense while rearranging the very tight garage workspace led to my leaning my right elevator haphazardly against an unstable structure, which predictably (in hindsight), caused it to tip over and hit the edge of my wing stand pretty hard. After many cuss words, I found the dent below in the trailing edge (which led to more cuss words).
I'm feeling fairly confident that this will require me to replace the skin, and while I will attempt to drill out all the rivets without blowing out holes in the spar and ribs, I'm not confident I will get through them all without making at least one show-stopping mistake (it will be good practice, I guess). In any case, I'm figuring I'm most likely rebuilding the right elevator from scratch to make up for my stupidity.
That said, wondering if anybody thinks this is safely repairable, and if so, if you can guide me to a YouTube video or something describing the technique I would use to even attempt this. I've thought about bringing it to a dent repair place before throwing in the towel , but it's bad enough that I'm not sure it's worth it. Thoughts?
Old 11-04-2018, 11:04 AM
wirejock's Avatar
wirejock wirejock is offline
Default Repair
I wouldn't because it's fairly easy and quick to build a new one. That said, I'm sure someone on here knows how it can be fixed and will post it soon.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 11-04-2018, 12:21 PM
fl-mike's Avatar
fl-mike fl-mike is offline
Since it is close to the tip, you may be able to smooth it out with a rounded end steel rod the same diameter as the trailing edge inside diameter. Inserted through the end rib gap.
Mike W
Venice, FL
N164WM
N184P reserved (RV-8QB)
Old 11-04-2018, 01:07 PM
So...dumb question--just get a steel rod with said diameter and gently roll it against the indentation with the hopes of pushing it back out? Do I hit it with the rod and try to pound it out, or is it just a matter of applying pressure? Does heating it help, or does that cause damage to the allow in some fashion?
Old 11-05-2018, 08:15 AM
Ron RV8's Avatar
Ron RV8 Ron RV8 is offline
I would replace the skin, no question...
https://www.youtube.com/watch?v=ec-eWnCr7cQ
Ron Townson
Okanagan Valley BC, Canada
RV-8 Completed Dec 2013
Membership renewed Nov 22, 2021
Old 11-05-2018, 02:24 PM
JonJay's Avatar
JonJay JonJay is offline
2024 T3 doesn't form very well. It doesn't like to be manipulated like some alloys. So, it may be possible to repair, but as others suggest, it might be easier to replace the skin.
Read up on how to remove rivets. It isn't intuitive.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 11-05-2018, 06:46 PM
I think I'm fairly convinced that I'm just going to bite the bullet and replace the skin. I'll try drilling out all the rivets...if I end up replacing the substructure, so be it, but worst case I'll end up with a few dozen practice runs on drilling out AD3 rivets...
Old 11-05-2018, 06:57 PM
wirejock's Avatar
Default Practice
Maybe buy the whole elevator.
Consider the old one practice. Drill it apart and get really skilled.
Larry Larson
Estes Park, CO
Disclaimer
Old 11-11-2018, 05:59 PM
I didn't say that, but that's what I'll do. The few extra parts won't cost that much when I'm already paying to ship the skin, I'm sure, but it will be good to practice my rivet removal skills on a dead part...
Old 11-11-2018, 09:06 PM
Jpm757's Avatar
Jpm757 Jpm757 is offline
Ive done dumber things than that. Just replace the skin, no biggie, and move on!
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017
(KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis, floats.
Building Javron Super Cub.
2020 dues gladly paid.
