I test flew an RV-10 that had the ignition advanced 45 degrees. Everything ran fine on the ground, with temps seemingly a little higher than normal for a new engine, but not show stopping.
On the first take off, the CHT's approached 475 degrees and were climbing arher rapidly by the time I reached the departure end of the airport. I reduced power to idle and nursed it around for a landing. Turning off the electronic ignition immediately solved the mystery as well.
As far as I know, the engine is still flying on that airplane. I think you should be Ok with your ground run.
Vic
 Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
