Go Back   VAF Forums > Model Specific > RV-9/9A
Old 10-31-2018, 09:11 PM
gfb gfb is offline
Default Yet another 9A speed thread
OK, so finally finished my wheelpants and dialing in the prop.
RV-9A, Titan IO-340 180hp, WW GA-200L prop
75% 2650rpm 9.2gph 164kts TAS 8500' (189mph)
65% 2540rpm 7.9gph 154kts TAS 8500' (177mph)
56% 2440rpm 6.8gph 149kts TAS 8500' (171mph)
50% 2400rpm 6.0gph 146kts TAS 8500' (168mph)
I was expecting a bit more at the top end; I was at full throttle, peak EGT.
Van's website numbers for 160hp list 186mph at 75%, I figured the extra 20hp would buy me 10mph?
RV-9A - started 01/2015, completed 07/19/2018, 500hrs 03/14/2020
RV-10 - started 04/2020
Last edited by gfb : 11-01-2018 at 10:02 AM. Reason: corrected IAS to TAS & CHT to EGT
Old 11-01-2018, 05:55 AM
N941WR's Avatar
N941WR N941WR is offline
Did you mean "True Airspeed"?
What is important is True Airspeed at 8,000' density altitude. That is the benchmark to use.
I think you will find your numbers will go up.
Also, why 2650 RPM? Is that all your engine could turn? At 9.2 GPH, I don't think you are producing full power. An O-320 will burn 9.6 GPH at 75% power.
At 8,000' DA, my O-360 spinning a Catto cruise prop will spin up to 2750 and my -9 taildragger will top out right at 175 knots TAS. To do that, I am burning a but more than 12 GPH, So I don't fly it at those speeds.
Good luck!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-01-2018, 07:20 AM
gfb gfb is offline
Good catch, I corrected IAS to TAS as that is the number I was actually reading.
The engine dataplate indicates 180hp at 2700rpm. The prop is limited to 2700rpm. I was trying to get the prop pitch to show 2700 rpm at full throttle around 8000'. I hadn't considered DA, I'll go out and re-do the test at 8000' DA and see what I get.
Old 11-01-2018, 08:18 AM
MarkW's Avatar
MarkW MarkW is offline
gfb,
Since i believe that is a ground adjustable prop you may find a little better speed at a little lower RPM @ 8500' and 75%.
I think the CS prop guys see better speeds at a little lower RPM.
I know sounds counter intuitive.
I typically fly around 8000' (9k-9.5k DA) and lean back to about 152- 155 kts and 7gph. If I look for best speed I can see around 160 kts at that altitude but my rpm is 2500.
This gives me enough prop that at the lower altitude and WOT I push the 2700 limit.
My guess is you would over rev at lower altitudes with your current prop setting.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 11-01-2018, 08:30 AM
gfb gfb is offline
Thanks Mark. Are you suggesting I increase the prop pitch? This does seem counter intuitive as you mention
Old 11-01-2018, 08:39 AM
MarkW's Avatar
Yes.
I would want to get input from CS prop guys but as I said I believe that they pull rpms back a little for best speed.
Plus I would assume you are over rev limit down low @ higher power percentage if you are 2650 @ 75%.
I bet you have very good climb with the current prop pitch.
Mark
Old 11-01-2018, 08:48 AM
lr172 lr172 is offline
I was expecting a bit more at the top end; I was at full throttle, peak CHT.
Assuming you mean Peak EGT. The represents economy cruise and is not full power. richen it up to 80-100 ROP for full power. I would guess that Van's uses that setting for their advertised speeds and this is loosely validated by backing it out of their endurance numbers.
20 HP should only buy you ~5 MPH.
Larry
Old 11-01-2018, 09:01 AM
grubbat's Avatar
grubbat grubbat is offline
Default Good question
I seem to recall the late Bob Axsom using max rpm of 2700 when racing to get peak HP and fastest speed. My engine produces max hp at 2700 rpm and I am limited by prop mfg to not exceed the rpm past that point. Also, my Vetterman trombone exhaust is tuned to 2550 to 2650 rpm. So, what does one to do? Horsepower and torque is a function of rpm and that?s one big factor to go fast. Another critical factor is prop rpm limitations and prop efficiency. I heard years ago that most fixed pitch props had peak efficiency around 2500rpm but who knows. I?ll takeoff at 2700rpm, about midfield when I am at traffic pattern, I?ll dial it back to 2550 to 2650 till 8000ft or so which takes a couple of minutes. I haven?t done any speed runs lately but I seem to recall that Bill Repucci?s -9 had me beat on top speed with his craft and that wonderful Catto prop. His prop is just good. Craig Catto should be proud.
Craig
RV-3 Sold
RV-4 Sold
1968 Twin Comanche - Sold
RV-6a Sold
1965 Comanche 260 - Sold
RV-9 Built and Flying
600A Aerostar - Sold and regretted
2000 Maule MXT-7 Project
1965 Maule M4 Bushwacker projectů till RV-15 shows up
Old 11-01-2018, 10:03 AM
gfb gfb is offline
Another good catch. I meant to say EGT.
Today I'll go out and re-run things at 8000' DA and 80-100 ROP. Stay tuned
Old 11-01-2018, 10:36 AM
MarkW's Avatar
Forget EGT's. Just keep playing with it until you get max rpm.
But as Larry says that should be just rich of peak.
Mark
