Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Interiors
  #11
Old 10-30-2018, 08:39 AM
Camillo Camillo is offline
I guess I will buy some polyfoam (Styrofoam) from Spruce to fill the gap behind the spar, which has a depth of approx. 3''. This material is 2 lbs./Cu. Ft. (32 Kg./m3) while Confor Foam is 3 times heavier (96 Kg./m3). This will help me on weight saving.
My only concern is if its stiffness would be equal or better than the blue CF. I don't want to "build" the seat with a softer material at the base. I asked Spruce for advice on this.
RV4 IO-320, Catto 3-blade, Christen, I-BILT
Flight time: 1 hour
Status: test flights
www.rv4.it
ROME, Italy
RV9A O-320 D1A, Hartzell C/S prop, slider, I-PRCA
Flight time: 350 hours
Status: SOLD
http://nuke.rv9.it
