10-25-2018, 08:06 AM
Leading Edge Landing Light Replacement BULB???
Has anyone replaced their old original plan bulb with an LED bulb instead of replacing the whole unit with a Baja or duckworks?
Also, does anyone know where I can get the nav LED bulbs that have wig-wag in them already? I check pilotlghts and their website isn't working or they don't sell them any longer.
D
RV6A: N6389-->N456RJ - Avionics Upgrade & Restoration COMPLETE & Flying
WTB RV4/8?- Looking for a 4 or 8 that needs some love and TLC. PM me if you have one!
Donations Paid- Thank you VAF!
10-25-2018, 08:20 AM
Originally Posted by dmat
Has anyone replaced their old original plan bulb with an LED bulb instead of replacing the whole unit with a Baja or ductworks
I cut the original Duckworks mounts to hold one spot and one flood light ($36 ea). Way brighter than the 55 halogen but not as bright as more expensive LEDs. Amp load is much less too.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
10-25-2018, 08:22 AM
would you happen to have a pic?
10-25-2018, 08:27 AM
Updated my post with a couple photos.
Ray
10-25-2018, 08:32 AM
Thanks so much! this will be a super helpful when trying to reduce amp power draw. Did you do this post build/retrofit?
10-25-2018, 08:34 AM
Yes, post build modification.
Ray
10-25-2018, 09:30 AM
$90 Hikari H4 thread
Great Hikari H4 thread.
$90 buys "13200 lumens"
http://www.vansairforce.com/communit...ghlight=Hikari
There is also a $70 version at "9600 lumens"
I did not see an actual Amp draw on them, if you need to reduce the typical 5 amp per bulb draw, I went with $120 each Rigid LED 1800 Lumen spots 3 years back with a Kuntzleman $40 wig wag. 2 Amps each, probably 1/3 better light than the first reply cheapies, but 2x better throw. They are silent and one step above basic $5 55W halogen bulbs at under 1/2 draw. The counter is you can upgrade to a bigger alternator at this cost if using auto alternators. If you need more light at night than 55W halogens, a separate issue than saving Amps, I'd go with the Hikaris, they probably draw 5 to 6 amps. More than that would melt the light wiring on new car headlamp harnesses.
Rigid Industries 62110 R-Series PAR-36 1800-Lumen Spot Lamp https://www.amazon.com/dp/B00AMELIJ6..._3DE0BbP0V3EQF
Flashing Nav lights are not FAR/CFR, plus the PSA set on Spruce were way noisy even ferrite choked. Under the red and green lens their color looked blueish vs green and orange vs. Red
If replacing Grimes Navs, for $50, more light, 1/4 the draw, try:
https://www.pilotlights.net/led-navi...2-bay15s-ba15s
Thread- http://www.vansairforce.com/communit...hlight=Nav+led
If you need to save more power, at $40 these are great anticollision beacons 360 degree, red- https://www.superbrightleds.com/more...g-lights/1905/
If you want the latest greatest VAF sponsor gear, these may be fit:
https://flyleds.com/products/#!/Comb...298/category=0
RV-6, bought from builder.
O-320, slider, carb, mags, FP
10-25-2018, 11:12 AM
Thanks! I would like to know what the HIKARI's draw. 12000 lumen is crazy for a direct replacement bulb.
D
10-25-2018, 11:35 AM
Agreed.
Judging by the tiny wires on my 2017 Honda harness and the hunted draw of a 5030 led at .2 amps, 12 per bulb, under 3 Amps each is my guess.
The later generation $90 kit is reported silent of EMI noise.
I believe the rating on the Rigids, not the Hikaris, so I put them in "quotes".
If doing again today, the $90 Hikari, if a drop-in fit, would surely be my first choice.
10-25-2018, 01:28 PM
the Hikari's are on order from Amazon! Should be here tomorrow.
