10-24-2018, 09:27 AM
I got reasonably good fit with my doors. I think this was in part due to the extra effort I put into securing the doors to the cabin top while bonding the two halves together. In addition to the clecos called out by the plans, I used duct tape to pull the doors securely into place all around the perimeter. Once the epoxy cured, when I removed the duct tape and clecos the next day, the doors laid flat against the cabin top.
Just a suggestion for those who haven't bonded the doors together yet.
Dave Macdonald
RV-10 First Flight April 1, 2020.  Currently in Phase 1
2020 VAF Dues Paid
10-24-2018, 09:36 AM
Thanks for the post. Duly noted!
10-24-2018, 10:03 AM
Worked very well for me
Use enough cleco's and I doubt you'll need to break out the duct tape. Very happy with the fit of my doors to the frame.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD reserved - under construction
donating monthly to the VAF - thanks, Doug
10-24-2018, 11:10 AM
I'm honestly wondering if it's because I have a pink top and grey doors! Either way, some work to be done!
www.N1017H.com
Tim Huneycutt, Capt, NCANG
PC-12 Pilot
N1017H RV-10 Flying 2019
EAA #: 1106970
2020 VAF Dues Paid!
10-24-2018, 11:15 AM
Filler is your friend
Bill Boyd
10-24-2018, 12:51 PM
I don't think so.
Same molds are being used for the gel coated parts, as were previously being used for the non-gel coated parts
Scott McDaniels
Hubbard, Oregon
10-24-2018, 02:24 PM
Originally Posted by rvbuilder2002
I don't think so.
Are the old (c. 2005) green tops different?
The finish inside looks different and AeroSport talks about a different fit for their overhead console.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
10-24-2018, 02:39 PM
The console fit is an issue with the inside surface of the top. The inside surface is variable by the guy doing the layup. The mold is only for the outside surface. Can't speak for anything but the green tops, but it is clear these did not use a mold for the interior side .
10-24-2018, 07:42 PM
You know when you have a long day at work and are tired but choose to build an airplane when you really should be resting? That equals dumb ideas and ludicrous jumps to conclusions.
I only had two screws in each hinge on both doors and the cabin side of the hinges weren’t tightened. So, I got all that resolved and then went back and added two washers under the rear hinge of the left door and wow, the difference is night and day. I still have some low spots on the doors but the situation is 100 times better.
I feel like I got two weeks of work done in an hour tonight!
www.N1017H.com
PC-12 Pilot
EAA #: 1106970
2020 VAF Dues Paid!
10-24-2018, 08:47 PM
I only had two screws in each hinge on both doors and the cabin side of the hinges weren?t tightened. So, I got all that resolved and then went back and added two washers under the rear hinge of the left door and wow, the difference is night and day. I still have some low spots on the doors but the situation is 100 times better.
Since you're working on the doors, you'll give both weeks back pretty soon doing stuff you thought would take an hour. ;-)
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
