Old 10-19-2018, 07:06 PM
Graham Graham is offline
Default Installation of Cowling insulation
Hi Folks,
I am trying to install vans aluminium foil and fibrefrax insulation blankets to my lower cowl of my RV6. I have the following observations, and have a couple of questions so would appreciate feedback from people who have done this.
1. FIBERFRAX.
I am using 1/8" thick material as I found the 1/16" sheet a bit fragile.
This sheet has bonded well to my painted cowl inside surface using Pliobond, so far so good.
2. FOIL.
My foil came from Vans wrapped in a tubular shape but the packaging has created "ridges" in it about 5" apart, parallel to the cylindrical centreline. Working the surface with a rag and running over the ridges with a putty knife helps, but they seem to be impossible to eliminate completely.
Anybody had similar ridges, and been able to eliminate them?
The sticky "inner" surface of the foil doesn't stick to the fibrefrax very well, has anybody bonded these two surfaces together eg using pliobond??
The foil does overlap the insulation blanket by 2-3"as recommended by most sources.
Getting a smooth exposed surface on the foil is proving difficult, not helped by the ridges. I am working the material outwards from the centre, but still end up with ridges.
Anybody got any recommendations on techniques to improve the foil exposed surface?
Graham
New Zealand
Wings attached.
Old 10-19-2018, 07:37 PM
Jpm757 Jpm757 is offline
Try using high temp RTV as an adhesive and a squeege or roller.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 350+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
Old 10-21-2018, 06:26 AM
DanH's Avatar
DanH DanH is offline
The pliobond isn't necessary. Just capture the fiberfrax between the foil and the painted surface.
"Wipe" it firmly with a plastic squeegee.
Dan Horton
RV-8 SS
Barrett IO-390
