Trim indication
Dale,
I don't know what trim indicator you have in the RV-12. It may be internal to an EFIS or maybe the older individual Ray Allen trim indicators like I had for the elevator & aileron trim. My elevator trim indicator was inop and the aileron trim indicator was only lighting up half the lights and jumping around intermittently. The trim in both directions appeared to be working just fine. I replaced both with the newer color LED RP4 trim indicators and now both trim indicators are working fine. It was an easy swap, the older wires are colored striped and the newer wiring is solid colors. Just wire the striped colored wires from the plane to the same solid color on the newer indicators and label as required.
Don't know if this helps as I am unfamiliar with the RV-12.
Here's what they look like and are available at Acft Spruce or direct from Ray Allen:
RV-8, Flying
Previous airplanes: Corby Starlet, Citabria, Cessna 140, Vari-Viggen, RV-3, RV-4
RV grin every flight
"Sure is nice to have smart friends"
2018 dues paid
