Old 03-30-2007, 08:31 AM
rvjoe rvjoe is offline
Default Tom Green
Thank you Tom Green!
I wanted to post this note of gratitude for the way Tom Green at Vans handled a situation that I encountered recently. It has to do with a mismatch of parts that I ended up with from Vans for mounting the Alternator on my engine. This posting is long in the details that follow, so skip the details if you wish, but just know that Vans has regained the respect of one RV6 builder for the way Tom Green handled a very frustrating situation.
I purchased a Firewall Forward kit from Vans a couple of years ago which included an Alternator kit with a Boss mount; but I ended up with an engine that requires a Case mount. At first it seemed like no big deal because Vans also sells a case mount bracket. I ordered that bracket from Vans, mounted it to my engine and hung the alternator. After mounting the bracket and alternator I discovered that the alternator was too far forward by 5/16 of an inch. I called Vans builder support to explain the problem I was having. I thought that maybe I was missing something. I just couldn?t believe that if I bought the alternator and the bracket(s) from Vans that I would have a mismatch like this. I didn?t see any way to get the alternator into alignment without milling down the backside of the front ear on the alternator by 5/16 on an inch. I didn?t want to do this (even though there would have been enough ?meat? to work with) because I didn?t want to end up with a morphodite. When I spoke with an employee of Vans builder support (I won?t mention his name) to see if he had any suggestions. He basically insulted me by saying that Vans doesn?t know what engine, alternator, brackets, etc? that the builder will end up with, and ?you have to remember that you are the manufacturer?. I told him that I am aware of this, but I thought that since I bought the alternator and the brackets from Vans, I didn?t think I would end up with a hodgepodge / mismatch. The conversation was going down hill and instead of getting any constructive suggestions, I got much more frustrated and I ended the conversation. I don?t want this to sound like a slam on Vans Aircraft but after I hung up the phone and reflected on the conversation, my whole opinion of Vans Aircraft changed.
I continued thinking (stewing) about the conversation for a few days. I decided to call back and talk to Tom Green just to let him know that Vans is selling parts (specifically the case mount bracket and alternator) that don?t work together. After discussing any and all of the possible reasons that I may be encountering this problem, Tom suggested that I call Plane Power at (877) 934-5700 and tell them what my application and engine are and get a part number from them for their kit. Tom said that Vans is now selling the Plane Power alternator kit as a ?Deluxe Alternator Kit? and it even has over voltage protection built in, but they don?t carry the one with the case mount. He said that he wants me to send back the Vans alternator kit and the bracket along with the part number for the Plane Power kit. He will then order that kit, have it drop shipped to me and just charge me the difference between the two kits. I was amazed at the way he dealt with this situation and the solution he came up with. I only called because I wanted to hear what his response would be to what had happened. I was hopping for a positive response because I didn?t want and I didn?t think it would be fair to let my opinion of Vans change because of one bad experience with the employee in the builder support. After speaking to Tom I called Plane Power and spoke to a nice lady named Linda. She said that they have exactly what I need and gave me the part number for their kit for my application. I sent my original parts back to Vans including a letter to Tom with the part number (that I got from Linda) and thanked him for his generous offer and solution to my problem. A week later I received the kit from Plane Power and I hadn?t even arranged to pay the difference yet. I now have the Plane Power Alternator with their bracket mounted to my engine and it lines up perfectly.
Kudos Tom! Thanks again.
Joe Radford
Peoria, Arizona
Old 03-30-2007, 09:18 AM
TSwezey TSwezey is offline
Default Thanks Gus!
When I spoke with an employee of Vans builder support (I won?t mention his name) to see if he had any suggestions. I told him that I am aware of this, but I thought that since I bought the alternator and the brackets from Vans, I didn?t think I would end up with a hodgepodge / mismatch. The conversation was going down hill and instead of getting any constructive suggestions, I got much more frustrated and I ended the conversation. I don?t want this to sound like a slam on Vans Aircraft but after I hung up the phone and reflected on the conversation, my whole opinion of Vans Aircraft changed.
Joe Radford
Peoria, Arizona
Holy cow! I just had an experience like that yesterday with Vans. I ordered the RV-10 wing kit 2 1/2 years ago. Apparently they did not have the nut plates for the wing tip in the bag with the other K 1000-06. The kit needs 108 of them. I received 24. 84 of them go on the two wing tips. I called and spoke with Gus who was very helpful and while he was looking things up my cell phone dropped the call. [couple sentences that violate the rules deleted here by dr] Luckily Gus was nearby and told the rep that he was handling it. The rep stated "Somebody is handling it!" and then hung up on me. Joe, you need to print his name so Vans can find out what this guy is doing to their business! So, I want to say thanks to Gus. Gus was also the pilot when I took my first ride in an RV-10 back at Sun-n-Fun two years ago.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 03-30-2007, 09:58 AM
DonPro DonPro is offline
Default nutplates
On my 6 and 8A kits the plans call for pop rivets to attach the wing tips. I chose to use #6 screws but knew I would have to order and pay for the nutplates and screws. I don't know about the 10 kit but think it would be the same.
Van is also clear on the point his parts are designed for the engines he sells and if you chose a less popular engine model you may have problems.
We should not complain about Van not chasing down every possible engine combination and expect improvements in all the kits with prepunching and new models.
Cut the man and his employees some slack. I have met many of them and they are good guys.
I think it is not them that are not being fair here.
My opinion
Don
Don Prosise
N642DP RV-6 180,CS,Flying
N848DP RV-8A IO-360-A1A Flying
Chandler, AZ
Old 03-30-2007, 10:58 AM
My opinion
Don
It is an O-360-A1A
Joe
Old 03-30-2007, 11:30 AM
Brantel's Avatar
Brantel Brantel is offline
It is an O-360-A1A
Joe
Can't get much more "Standard Van's" than that!
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 03-30-2007, 01:17 PM
My opinion
Don
First of all, the only instructions I have for putting on the RV-10 wing tip is with nutplates! Most Vans employees are great! There is just one or two bad seeds and it just might be one. If you noticed both of us were thankful for the employees that helped us. You just don't understand how rude this guy was!
Todd
N110TD
Old 03-30-2007, 01:29 PM
rvbuilder2002's Avatar
Default Not Neccesarily
Lycoming has been building engines designated O-360 A1A's for decades.
They are not all exact copies of each other.
Joe mentioned needing a case mount for his alternator.
All of the engines supplied by Van's have a boss mount.
Scott McDaniels
Hubbard, Oregon
