Old 10-14-2018, 08:02 PM
gfb gfb is offline
Default Brake Drag?
Finishing up wheelpants (yes, I know...) and had the plane up on jacks. Noticed a bit more brake drag than I was expecting, very similar to this video:
http://www.youtube.com/watch?v=-JFTeGMazqs
I have Beringer wheels/brakes and the piston is definitely all the way up. I can lightly pry the pads apart and then the wheels spin freely.
Is this an expected about of drag?
RV-9A - started 01/2015, completed 07/19/2018, 500hrs 03/14/2020
RV-10 - started 04/2020
Old 10-14-2018, 08:14 PM
PCHunt PCHunt is offline
You can usually hear brake drag easily. If you don't hear a noticeable brake noise, then the bearings could be too tight.
Loosen the axle nut until the bearings are "too loose", and try again. If no change, it's the brakes. If it spins nicely, then the bearings were too tight.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 10-15-2018, 08:27 AM
gfb gfb is offline
It's definitely the brakes. As I mentioned, the problem goes away if I pry the pads apart a little. I also checked by removing the axle nut and I get the same problem.
Old 10-15-2018, 09:27 AM
Ralph Inkster Ralph Inkster is offline
Is this plane already flying? If so is this condition new since installing the wheel pants? In this case maybe the new brackets are applying side pressure on the calipers, or similar pressure against the brake line?
If this is a new plane, have the brakes been ?burnt in?? It might loosen up after taxing a bit.
Is this both wheels. Or just one side?
Ralph
built a few RVs, rebuilt a few more, hot rodded some, & maintained/updated a bunch more
Old 10-15-2018, 11:10 AM
gfb gfb is offline
Both sides, 90hrs on the plane, no wheel pants.
