Old 10-13-2018, 07:43 PM
dmat dmat is offline
Default Subpanel on a 6 tip-up structural?
Hi all, about to cut the subpanel almost in the middle of the subpanel and wanted to know if it?s structural? There is a bracket that hold the 2 subpanel as together.
D
RV6A: N6389-->N456RJ - Avionics Upgrade & Restoration COMPLETE & Flying
WTB RV4/8?- Looking for a 4 or 8 that needs some love and TLC. PM me if you have one!
Donations Paid- Thank you VAF!
Old 10-14-2018, 09:52 AM
Snowflake's Avatar
If you're referring to the panel that is riveted to the top skin, and has longitudinal ribs riveted to it that extend forward to the firewall, yes, it is structural.
Rob Prior
Old 10-14-2018, 02:25 PM
gasman gasman is offline
D
It depends on how and where you are going to cut it. Sketch up the cuts and send them to Van's for their OK.
Properly reinforced, you can cut good sized chunk out of the center.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 11-04-2018, 07:48 PM
I am cutting right where the brace is for the canopy jettison mechanism. I don?t have the mechanism anymore but th brace worries me.
Old 11-05-2018, 07:51 AM
Snowflake's Avatar
As @gasman suggested... Make a sketch showing where you want to cut (maybe photocopy the plans and mark up the page showing the piece), and send it to Van's and ask their opinion. They will guide you.
Rob Prior
Old 11-05-2018, 07:58 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
On my -6A I found that the sub-panel would lie flat even before parts were cut out of it. The parts just were not very flat as shipped.
A 3/4 by 1/16 angle riveted on top of the lower flange helped to keep things square.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
