Originally Posted by gmcjetpilot
Should not be an issue. The issue is the antennas being too close (recent thread discussed that). I would not tie them physically together just for warm fuzzy. May be give them some space if able. As far as TX/Com antenna spacing 3 ft per book but 18" has been found to practically work in service.
Garmin only gives caution on the cable being routed 12 inches away from an ADF co-ax cable....
So, if you don't have one of those antique paperweights, you are OK....
gil in Tucson
