Old 10-09-2018, 10:34 AM
wnplt wnplt is offline
Default Sealing access panels?
My builder cut and installed access panels in the top fuselage forward of the canopy. I love them but need to get them sealed up for water intrusion. What?s the best way? Have heard proseal dried up then installed. Any type of very thin rubber gasket material?
Open to ideas....
Old 10-09-2018, 10:50 AM
Assuming the AC is already painted, you could put down a bead of RTV, cover with a layer of cling-wrap or wax paper and loosely install the cover. Once cured you have a gasket.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 10-09-2018, 11:15 AM
rocketbob's Avatar
This.
Low-adhesion Proseal. Mixes to a slightly purple color.
https://www.skygeek.com/prc-desoto-p...r-sealant.html
good stuff.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 10-09-2018, 12:26 PM
It?s not painted yet. It goes next month. I would want something that still allows access to the panels for maintenance.
Old 10-09-2018, 02:59 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Silicon Grease
I have the access panel, which I made --- I use a heavy silicon grease for the sealing --- I tried thin rubber gaskets, silicon sealer, Permatex, etc --- nothing worked as good as the silicon grease. I have the panels off and on frequently -- the grease makes removal and reinstall very easy.
I can send pics if you will email me.
By the way, I could not do much on the airplane without my access panels - best mod (of many) that I made.
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 10-09-2018, 04:41 PM
Bevan Bevan is offline
Assuming you don't need into the access panels very often, you could put a sheet of automotive vinyl over them.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
