Old 03-29-2007, 03:26 PM
MattPearson MattPearson is offline
Default Case mount or boss mount? Which is which
I know this may sound like a dumb question, but can someone post some pictures or just describe the difference between the two when it comes to mounting and alternator?
Old 03-29-2007, 03:53 PM
Jekyll Jekyll is offline
Go to this web page:
http://www.plane-power.com/Mount_Systems.htm
If you are running a lycoming or lyclone you'll be needing one like this in the boss mount:
http://www.plane-power.com/AL12-EI60.htm
This is new model that Van's sells for $375. It has internal regulation and a crow bar. Bob Nuckols of the Aero Electric Connection recently came out and said this as the only internally regulated alternator he recommends.
It's only a dumb question if you don't ask it before buying the wrong mounting style.
Jekyll
Old 03-29-2007, 04:43 PM
Mel's Avatar
Mel Mel is offline
The boss mount has a "boss" cast onto the crankcase. The case mount has a bracket that mounts to the spine bolts.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 03-29-2007, 05:40 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default Boss is better than case
I'll Add..........
Most lycomings made in the last 3 decades have boss mount. The older engines are the ones with case mount. Boss mount is much better. The case mount brackets work but are subject to more bending and likely to crack easier.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
Old 03-29-2007, 08:03 PM
Awesome! Thanks gentlemen
