Old 10-07-2018, 06:20 AM
olyolson's Avatar
olyolson olyolson is offline
Default Removing flap tape
The flap tape on my-8 was installed on the top of the flap many years ago and needs to be removed as it has turned yellow and brittle with age. I plan on taking the flaps off and doing it on the workbench and putting flap tape on the inside top rear skin instead.
I have heard of a sanding wheel you can attach to a drill that has rather soft bristles that won?t hurt paint but I am not familiar with it. Anyone know where I can get one? I can do it by hand a little a a time but it comes off in tiny pieces and would take quite a while doing it that way. Is there another method that would work?
RV-8, Flying
Previous airplanes: Corby Starlet, Citabria, Cessna 140, Vari-Viggen, RV-3, RV-4
RV grin every flight
"Sure is nice to have smart friends"
2018 dues paid
Old 10-07-2018, 06:25 AM
This approach works:
http://www.vansairforce.com/communit...t=eraser+wheel
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 10-07-2018, 06:46 AM
rv7charlie rv7charlie is offline
Something to consider: After you get the flaps off, take a look at the underside of the top wing skin above the tape location. If you see any scratching, that's what you'll eventually see on the flap top skin where it contacts the new tape.
Old 10-07-2018, 06:50 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
I?ve had good luck using a heat gun (sparingly) to first soften up the tape. Get a corner up then slowly pull away applying heat as you go. Not too much heat. Start off with not enough heat and work up to what you need. You will quickly figure out what does the trick. With care the underlying paint comes out perfect.
Clean up the tape residue with you choice of goo remover.
Carl
Old 10-07-2018, 08:22 AM
Ironflight's Avatar
VAF Moderator / Line Boy
This:
The only purpose of flap tape that I can tell is to protect the paint on the flap. It?s not required to make the flap operate, and it would take a lot of years to wear away the underside of the wing skin. The tape is very soft (compared to aluminum), and at least out here in the west, it will pick up all sorts of grit - you?re making sandpaper essentially. So decide what you want to scratch before you apply it to one side or another.
Two of our RV?s have stainless tape on the flaps - the third will get it when I get motivated to take the yellowing tape off.....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 10-07-2018, 08:48 AM
DanH's Avatar
DanH DanH is offline
Heat gun, plastic scraper, carefully.
This is the best commercial adhesive remover I've found. I buy gallons on eBay to remove adhesive from truck bodies after vinyl wrap removal. Turns adhesive into something like slime, which can be removed with a plastic scraper.
http://www.rapidtac.com/rapid-remover.html
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-07-2018, 09:01 AM
N941WR's Avatar
N941WR N941WR is offline
Good luck with the removal.
I put the tape on the underside of the wing, not on the flap. Both the tape and the flap have held up well.
Keep in mind, my plane is a -9 with its slotted flaps. My flap does not slide against the tap like a shortwing RV's flaps might.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-07-2018, 11:47 AM
olyolson's Avatar
Default Flap tape
Thanks for the great replies. That eraser is exactly what I was looking for, heard great results.
RV-8, Flying
2018 dues paid
Old 10-07-2018, 12:54 PM
gasman gasman is offline
Instead of removing the flap, first try just disconnecting the link and working with the flap still attached. It is secured, and at a good working position.... it worked for me.
Heat, and then a lot of goo gone.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 10-07-2018, 01:26 PM
olyolson's Avatar
Default Flap tape
Warren,
If I do that is there still enough room to get underneath the rear skin to put the flap tape underneath?
RV-8, Flying
2018 dues paid
