Old 10-06-2018, 05:55 PM
Nova RV Nova RV is offline
Default 8130-12 Eligibility Statement questions
I think I'm reading too much into the section about listing any commercial assistance. Does a situation like Stein supplying a cut and painted panel fall under commercial assistance and therefore should be listed, or are they merely supplying parts? Or, are the feds looking for something along the lines of you hiring a company like Synergy for pay to provide building assistance?
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
RV-14A kit # 140243 (flying as of 11/18)
www.mykitlog.com/chrismoon/
Old 10-06-2018, 10:21 PM
RV7A Flyer's Avatar
Van's kits have been evaluated and found eligible for E-AB A/W certs. I don't think anybody cares about panel stuff as you mentioned (you still have to route and connect a ton of wires and whatnot).
See this list:
https://www.faa.gov/aircraft/gen_av/...it_listing.pdf
2019 Dues paid!
Old 10-06-2018, 10:35 PM
lr172 lr172 is offline
I suppose it could be a grey area, but I would think of it as purchasing a component. We don't list lycoming as commercial assistance because they assembled our engine, even though we are able to buy all of the engine parts individually and some builders do just that.
They are really looking for paying for commercial assistance to do the major build work that you do.
Larry
Old 10-06-2018, 11:21 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Larry
Not too grey according to AC 20.27 - avionics are specifically called out, as well as engines and props -
(2) Identifying Which Items Can Be Installed Using Commercial Assistance. You may get unlimited commercial assistance for non-checklist items on a kit evaluated by the FAA. A non-checklist item is a task or process that is not listed on the Amateur-Built Aircraft Fabrication and Assembly Checklist (2009). These items also include painting and the installation of interior upholstery or avionics. Such a task or process would not be required to be personally completed by the amateur builder for the aircraft to receive an airworthiness certificate under § 21.191(g). Other non-checklist items include fabrication of engines, propellers, wheels and brake assemblies, and standard aircraft hardware.
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/4db2c5cd655cb3cc86257647004af4ee/$FILE/AC%2020-27G.pdf
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-07-2018, 06:37 AM
Mel's Avatar
Mel Mel is offline
The good part about these "excepted" items is that if you have them done, it doesn't count against you, but if you DO them yourself, you get credit toward the 51%.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-08-2018, 11:12 AM
Thanks guys for the info, big help!
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
