Old 09-30-2018, 06:28 PM
jwilbur jwilbur is offline
Default Alternate Static Test
Question: If I'm flying at 3000 feet MSL, 120 KIAS, OAT ~ 55 F, fresh air vents in the cabin open, and I switch to my alternate static source (what you would do if the static ports got plugged with ice), what would you expect to see on the Altitude/IAS indicators? I tried this as a test today. I was expecting to see a jump of some sort but I saw nothing. Switched to cabin-air for about 3 seconds before switching back. I tried it twice. Would you assume there's a leak in my static system or is this an inconclusive test?
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
RV-10 Build Log
Old 09-30-2018, 06:46 PM
Bevan Bevan is offline
Yes, I would suspect a leak in the static system. If it?s tight, you should see the altimeter jump/drop when activating the alternate static switch.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 09-30-2018, 07:05 PM
Bavafa Bavafa is offline
Bevan
Agreed completely. Mine always did it to the point that I was afraid to damage my ASI due to sudden change in the pressure.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 09-30-2018, 07:23 PM
When I checked it during phase 1 it jumped as expected. But I didn't record the conditions at that time, just the very useful phrase, "checked alt-static. It works." I was just wondering if maybe there are conditions where there might be a less obvious jump.
I'll be looking for a leak.
Thanks.
Phase II - 11/2017
RV-10 Build Log
Old 09-30-2018, 08:42 PM
For the leak, start at your alternate static port or other connections within the cabin. If there is no jump, good chances are that you are on your cabin pressure the entire time. I would suspect a change even with a leak if it is not within the cabin.
Mehrdad
Dues paid
Old 09-30-2018, 10:09 PM
1. Try it again with air vents closed.
2. Watch your indicated airspeed for changes, valve open/closed.
3. In my airplane going to alternate static shows a very small change on the main EFIS - because the air-data computer is in the back, close to the outside static opening and far from the alternate opening. My backup EFIS has its static port close to the alternate valve, and it shows a bigger difference when opening the alternate.
Old 10-01-2018, 05:42 AM
F1R F1R is offline
Default Another possibility.
Are you certain the alternate static valve is actually working? if the alternate valve is not opening, or if the internal line is blocked you would also see no change.
Old 10-01-2018, 09:48 AM
Good point. I've been assuming a working valve. This is the easiest thing I can check and will do so first. Thanks very much for suggesting it.
Phase II - 11/2017
RV-10 Build Log
Old 10-01-2018, 05:06 PM
Default Update
Well,
I systematically tee-ed off each section of my static system. There are no leaks and the valve works fine. I thought maybe a tube hadn't been seated properly somewhere and I had fixed it in the process of checking it while unplugging and plugging things back in. .... I took it for a flight. Brought it to 6000 feet. I tried the valve with vents open and closed. The only thing I see is a quick little jump in the VSI (both main and backup screens). Definitely not as dramatic as I expected but it does appear to be working.
Phase II - 11/2017
RV-10 Build Log
Old 10-01-2018, 05:15 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
One easy test on the entire system.
Pressurize, (or preferably suck ) your static system on the ground as if you were doing a leak test, say to a few 100 ft on the altimeter, with the alternate static switch closed. Use one of the static ports and seal off the other static port.
Open the switch and the altimeter should quickly return to measure local altitude.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
