Old 03-29-2007, 02:49 AM
bryanflood's Avatar
bryanflood bryanflood is offline
Default Double floor
Hi, I have an RV-9A and my wife constantly complains about the vibration of the floor, not really the noise, just the vibration. For some reason she seems really worried about it and has taken to removing her feet from the floor or putting large blankets under her feet. How horrible, I also notice the vibration but it's not particularly offensive to me or does it seems all that out of line for an aircraft w/o an interior. I think I would like to install a "double floor" with a 1/4" light ply. I know there are other RV'ers who have done this, an I would like feedback on there experience:
1. Did/does it reduce vibration...
2. How did you mount the floor?
I worried that an impropperly mounted floor will just transmit the vibration and not adress the problem.
Bryan
Old 03-29-2007, 03:14 AM
MrNomad's Avatar
MrNomad MrNomad is offline
Default More info please...
Please provide some more info.
How bad is it at 2300 rpm, 2400 rpm and higher?
What engine/prop combo do you have?
Did you balance after assembly?
Barry - Tucson
RV9A Superior O-360 (an amazing experience)
Dynon AP Garmin Sensenich F/P
2020 Dues paid. Thank u DR!
Old 03-29-2007, 03:31 AM
smenkhare smenkhare is offline
How about just putting down a layer of foam like camping mats are made of?
Peter
RV-10 wannabe
Old 03-29-2007, 05:49 AM
jonbakerok's Avatar
jonbakerok jonbakerok is offline
Default Foam between the stiffeners
The vibration is caused from the exhaust pulses beating on the floorpan. You will be amazed at the difference if you fill the voids between the stiffeners with 3/4 foam and then lay carpet over that. I used a black vinyl nitrile foam that's fire proof and doesn't absorb liquids. I'd give you a part number but it doesn't seem to be in the Spruce catalog anymore.
Jon Baker
RV6A sold, RV4 in-progress
Houston
Old 03-29-2007, 10:13 AM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up AC Spruce
Jon .... I think you are talking about the black stuff on the top of this page...
http://www.aircraftspruce.com/menus/ap/soundproof.html
Just bought some for my Tiger... it's much denser than furniture foam, but not much heavier.
Note - the weight quoted is per linear ft. - it's 4 ft wide...
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 03-29-2007, 11:03 AM
yakdriver yakdriver is offline
Get an Aero Classics carpet. Comes with the 3/4" dense foam bonded to the carpet. Also has heel pads under the rudder pedals and it fits perfectly. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 03-29-2007, 06:45 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default Remove the noise
Get a new wife? I'm KIDDING (Do what ever you can to please her, she is more important than the plane, yes I said it and mean it.)
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
Old 03-29-2007, 08:46 PM
Harvey L. Sorensen Harvey L. Sorensen is offline
Default Floor vibration
I have no floor vibration on my 9-A. None. I put sections of 3/4" Super soundproofing betweenthe ribs in the floor and fitted 1/4" plywood over the soundproofing execpt for the center tunnel, I left that metal. I then painted the plywood with wingwalk paint for traction so I can back out of the plane. Works great. I also cut some groves in the soundproofing to run wires from front to back they are now under the plywood I hope I never need to get at them. But the plywood is not hard to remove but it is hard for me to get at.
I also put 3/4" soundproofing on the back side of the firewall.
Would or will do the same again.
Old 03-29-2007, 09:24 PM
walter's Avatar
walter walter is offline
Ditto on the Aero Classics carpeting with integrated foam backer.
Knocked down most of the vibrations. Since I installed it, my feet are
comfortable as ever. Plus, it looks great and does have some sound
absorbtion properties, which I slightly noticed.
Walter Tondu
Flying RV-8A - Fastback, IO-390, G3X Touch, 74 HRT
Prior RV-7A Build Log
Old 03-30-2007, 05:55 AM
jonbakerok's Avatar
Default That's the stuff.
gil in Tucson
That's the stuff!
Jon Baker
Houston
