09-28-2018, 06:50 AM
Originally Posted by joe gremlin
Doing ground idle and runups with the top cowl off is one thing. Going flying with it that way it something else entirely...
I didnt get the impression the OP or subsequent replies were discussing flying the airplane with any part of the cowl removed.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
09-28-2018, 07:22 AM
By George you're right. Shows what happens when I try to read before my brain is warmed up. Oops.
09-28-2018, 07:39 AM
True, but while balancing a prop you will go to full throttle to get a complete vibration profile.
The point someone made about vibration readings changing with/without the cowl may be valid... If nothing else a lower cowl vibrating on its own may add noise to the reading.
That all said, when I did my dynamic balance, I did it with top cowl removed, bottom in place, and had no issues. It feels smoother now.
Rob Prior
09-28-2018, 10:38 AM
Leak Check
Originally Posted by kkmarshall
I do it after every oil change to ck for a possible leak at the filter. No issues rubbing against the spinner or flopping around.
Thread drift, but...
I'm curious why you don't do the leak check before replacing the lower cowl?
Skylor
09-29-2018, 09:26 AM
I don't pull the bottom cowl/sump screen for a routine oil change,just at CI time. I can fish a drain hose to my quick drain from the cowl exit so that is why the bottom cowl is still on. I know that may be heresy to some to only pull the sump screen every other oil change!
Keith
329DR RV10-bought flying
Continually upgrading/tweaking
09-29-2018, 09:42 AM
That sounds to me like you are only doing a visual inspection of the lower engine area once a year.
The few minutes extra to remove the lower cowl every oil change for a good "look-see" down there would seem to be a wise thing to do.
PS - per Lycoming, the oil suction screen is a 100 hr item -
Oil Suction and Oil Pressure Screens – At each 100-hour inspection remove suction screen. Inspect
for metal particles; clean and reinstall.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
09-29-2018, 11:44 PM
Oil Suction and Oil Pressure Screens ? At each 100-hour inspection remove suction screen. Inspect
Gil beat me to it. +1.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
09-30-2018, 06:38 AM
Also I?m fairly certain this crush washer must be replaced each time the screen is removed per Lycoming.
https://m.aircraftspruce.com/pages/ha/washers/an900.php
RV-4, #audiaviator
"Poise under pressure is the single most valuable thing you can have as a pilot. Make mistakes, take corrective action as quickly and calmly as possible and press on."
09-30-2018, 08:14 AM
How
How does it go from running the engine with the top cowl off to crush washers.....
Cheers, Hugh
CF-HGD
09-30-2018, 08:24 AM
+2
I also don't check the suction screen every oil change, however, I always pull the cowl and do a visual check. I have been able to catch numerous issues early. This is especially important in the first 100+ hours as many bolts/nuts need to be snugged early on as heat does its thing.
Larry
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
