Panel Cutting: Mixture/Throttle Placement?
Hi All,
I am going to be attaching a 2.5 inch panel attached under my main panel to house the EXP bus on the pilot side and the throttle/mixture/flap switch/oil cooler vent.
Couple of questions:
1) is the mixture control usually center on the panel? I would assume yes
2) what is the standard separation (center on center) between the throttle and mixture?
3) For functionality, I was thinking (from left to right) placing throttle---mixture---flap switch---oil cooler vent. Has anyone done that in the past?
Any guidance would be appreciated!
D
RV6A: N6389-->N456RJ - Avionics Upgrade & Restoration COMPLETE & Flying
WTB RV4/8?- Looking for a 4 or 8 that needs some love and TLC. PM me if you have one!
Donations Paid- Thank you VAF!
