03-28-2007, 09:48 AM
electrical questions
Hi all,,, I've been studying the aeroelectric book and I had a question.
Planning an io360 in an rv8... battery in back. why is it (or why not) good or bad, to have the starter contactor and the master contacter in the back with the battery?
thanks
Mike
Mike Bourget
Ottawa, Ontario
03-28-2007, 09:58 AM
Senior Curmudgeon
Put the master close to the battery.
Put the starter contactor close to the starter, on the firewall.
If you put the starter contactor in the rear, you will need to run another hot lead (#8 or so) forward to the buss/charging circuit etc.
Mike
03-28-2007, 10:00 AM
I don't have an aft battery so I haven't studied the issues, but...If it were me, I don't think I'd want an always-hot, unfused, heavy-gauge line (or two?) running all the way through the airplane with no way to shut it off.
03-28-2007, 10:10 AM
Senior Curmudgeon
That is what the master solenoid/contactor is for.
The hot line forward is run through the master. You are right about it being unfused, though.
If there was no hot line from the battery, there would be no way to charge the battery, and the "flywheel" effect on the system voltage would not be there.
Also, in the event of a failure of the alternator, or regulator, you would have a dead system.
When the battery is in the back, you must have a line forward that stays hot as long as the master is on.
Mike
Reason: more info
03-28-2007, 10:22 AM
Or just put an Odyssey battery on the firewall like in the RV-7, and solve all sorts of issues. Do you REALLY NEED the battery in the BACK?
Dan Checkoway RV-7
03-28-2007, 10:30 AM
Mike
He was asking about putting the contactors up front. If you put the contactors in the back with the battery, then you don't always have an always-hot line running all the way through. That's the point I was trying to make, but I didn't do it very clearly...sorry.
03-28-2007, 10:37 AM
Senior Curmudgeon
Paul, you are correct about rear batt, front contactor--------sorry if I mis-understood what you were getting at.
Mike
03-28-2007, 11:12 AM
With the battery in the back, you should place your master solenoid and battey buss (if you have one) as close as possible to the battery. The starter solenoid should be placed up front somewhere. I like it behind the firewall so that I don't have a hot wire running through the firewall.
In this situation, the only unprotected wire is the one running from your battery to the master soleniod and battery buss. I oversized these wires to handle the loads. They are less than a foot long.
You can power your master buss from the hot side of the starter solenoid. In any event, the master solenoid is used to power off this fat wire running to the starter solenoid should a problem occur.
The only problem a rear battery creates is the weight of running heavy 2AWG wires from the back of the airplane to the front. Other than that, the electrical protection is identical to a forward mounted battery installation.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
03-29-2007, 08:30 AM
thanks guys,,, was pouring over Aeroelectic again,, I think I get it now. Randy do you mind if I pull some info from your diagrams?
M
Mike Bourget
Ottawa, Ontario
03-29-2007, 08:51 AM
That's what they are there for!
Randy Pflanzer
Greenwood, IN
Paid through 2043!
