  #11
Old 09-21-2018, 05:22 AM
snopercod's Avatar
Originally Posted by Flying Canuck View Post
The most surreal part of the flight tonight is that I didn't need to schedule anything and I didn't need anyone's permission.
I shudder when I think of the years when I had to rent. Congratulations Claude!
(2020 dues paid)
Old 09-21-2018, 07:15 AM
Flying Canuck Flying Canuck is offline
Originally Posted by Jim Frisbie View Post
Do you have AOA?
I fly my approaches much slower than you describe
With AOA my app speed is about 60kts with touch down about 54kts
I do have AOA, and it's calibrated. I may well bring my speeds down once I get more comfortable with it. The only stalls done so far were for the AOA calibration and were done power on and fully loaded, so the stall happened at 55kts. I know the stall speed will be much lower in landing configuration, once I've found that number I'll see what a lower approach and landing speed feels like. For now, the faster speeds are working and it keeps the nerves about dropping it on in check. I have noticed though that when I'm doing a touch and go, it wants to jump off the runway pretty much as soon as I start to advance the throttle. I'm sure that would ease up if I'm not doing lift off speeds on rollout. My landing distances aren't great at these speeds, but since the first exit on the primary runway at my home airport is about 5000' from the threshold, landing short is a nuisance. The other advantage to the higher speeds, or perhaps the perceived high performance, the flight service station here views me as a high performance aircraft and treats me quite well because of it.
Claude Pitre
RV-9A #91081, C-GCPT
Dynon SkyView HDX, IO-320 and WW 200RV C/S. Flying as of August 6, 2018
Interactive map of all of my flights here
Old 09-21-2018, 09:47 AM
Steve Melton's Avatar
my stall speeds for reference, gross weight:
stall clean = 51 kts
stall flaps = 43 kts
they are lower at light weight.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
Old 09-21-2018, 10:39 AM
Your flaps stall speed is exactly what Van's lists. I wonder if that was intended to be a landing configuration number. My 55kt experience doesn't look to be too out of line consider that was clean, heavy and power on. I'll definitely be finding my numbers on my next flight.
Thanks for sharing those Steve.
Claude Pitre
Old 09-21-2018, 12:43 PM
Shark's Avatar
Shark Shark is offline
Default Grin away
Not sure how you all feel but it is very nice to have very little challenge when landing. And yes stall speeds are also same as Vans advertises. Congrats Bud
Donaven
Lake Elmo MN.
RV9A
Old 09-21-2018, 04:13 PM
Don Patrick's Avatar
Don Patrick Don Patrick is offline
Thumbs up Right on
Congrats Claude!
Enjoy your ride!
Don
RV-8 build
DONE!
C-GLOV
http://www.mykitlog.com/Don%20Patrick
Old 09-22-2018, 05:40 AM
Paul from Flyleds's Avatar
Paul from Flyleds Paul from Flyleds is offline
All of these picture requests are great, but I'll need to install that flux capacitor before I can get the ones I didn't take. Maybe I should add "take some pictures" to my checklists.
Hmmm, perhaps there's a new DIY kit for me to sell there...!
Paul McVitty
Flyleds.com
VAF advertiser
Old 09-22-2018, 07:53 AM
Great idea Paul! Your led lights would probably save a chunk of a jigawatt and let you make it small enough for panel mounting.
Your light kit worked out great in my plane - I need to check my left strobe as it's not working, but that's likely a wire that's come loose. Come to think of it, I owe you a picture don't I.
Claude Pitre
