Old 09-19-2018, 08:32 AM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default Measuring Crankcase Pressure
What are folks using to substitute for the oil filler cap/dipstick when installing a pressure measuring tap to measure crankcase pressure? As much as I have searched, I can't seem to find any definitive information on the thread size. I'd like to find some sort of threaded metal or plastic cap that fits the filler tube that I could then drill and tap for a tube fitting to connect to my digital manometer.
Any ideas?
Dan Langhout
2020 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
665 hours and counting . . . .
Now based at Moontown (3M5)
Old 09-19-2018, 09:13 AM
RVDan RVDan is offline
Can't help on the tread info, but why not use one of the existing pipe threaded ports on the accessory housing that just go into the crankcase volume?
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
Old 09-19-2018, 09:16 AM
Alan Bumbaugh Alan Bumbaugh is offline
Default Dip Stick Threads
Dan,
I just measured mine and both appear to be 1-1/8 O.D. X 12 inch pitch. The cap with the dip stick major diameter is smaller.
Alan
