You are correct that the length is the same for the -7 and -9 and that the center -to-center of connecting rods should be approximately 6 5/8" with some minor adjusting for your installation. My drawing (33) says your material is hex (VA-256) while the -7 is round (F-759A).
Sounds like you will need to do some trimming.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
