03-27-2007, 12:57 PM
Fuselage Rotator?
J.C. Whitney has a couple of (relatively) affordable engine stands that to my unpracticed eye appear to be easily adapted for use as a fuselage rotator. If so, they sure would be a low cost alternative to the real deal. Has anyone modified a pair of engine stands from J.C. Whitney to serve as a fuselage rotator and if so...how did it work out?
http://tinyurl.com/yp99ow
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
03-27-2007, 01:31 PM
Mark
RV-8 C-GURV (Flying since Nov 2004) - Sold
Scratch building 4pl Bearhawk
Flying a '79 Maule M5-235C
President EAA Chapter 245
03-27-2007, 02:23 PM
I know a builder who built one out of 2 Harborfreight engine stands ($60 each).
Put them on blocks instead of the wheels.
Greg Piney
RV-8 2547
Empennage Done!
Beginning Fuselage Final Assembly!
(Tub finished, on to Landing Gear).
03-28-2007, 08:46 AM
Harbor Freight - worked fine
I recently mounted my 8 fuselage on a Harbor Freight engine stand and all is well. I used 2x4s with plywood stand-offs for the "cross" part on the firewall. Bolted the engine adapter plate straight to the 2x4s. There is quite a bit of slop between the engine adapter tube and the "socket" tube on the stand itself, so I just have the tail propped up on two milk crates with a pad on top. Currently rolled 90 degrees left, and working on the roll trim mounting. Sorry no pictures, as my digital camera died recently.
William Slaughter
Houston, TX
RV-8QB
03-28-2007, 03:00 PM
Be very carefull using the three legged engine stand. They will turn over very easily with an engine mounted.
Bob
03-28-2007, 05:11 PM
Got Picture!
Just realized I have photo of my friends setup. He sandwiched the two stands with a couple of 2x4x12' s.
[img=http://img410.imageshack.us/img410/1386/img0180dq8.th.jpg]
Greg Piney
RV-8 2547
Empennage Done!
03-29-2007, 08:20 AM
hf/rotater
I
did mine on the hf engine stand as well (7a). got the 1000 lb stand for the same price as the 750 (it was on sale for 39.95, and they had a $5 off coupon). the 1000 lb has a lateral extension on the "third" leg, essentially turning it into a 4-leg stand. found the angle of the mount part to be non-horizontal, so i cut a coupla pieces of 1-1/2" 4130 square channel, got some longer bolts, and jacked it up at the junction of the vertical and horizontal cross-members, which made the mount more orthogonal. used home depot angle iron for the firewall mounts. was a little extra work (not much), but i probably have <$60 in it all told. used a "sling" made from 2x4's and scrap carpet for the tail.
john prickett (VAF 449)
manchaca, tx (suburb of austin)
rv-7a finish kit
N337JP (reserved)
03-29-2007, 05:42 PM
Two hard points on the ceiling will beat any kind of floor stand. Clear floor, comes with height adjustment, and I've yet to tip over a whole building. <g>
Dan Horton
RV-8 SS
Barrett IO-390
03-30-2007, 12:36 PM
pre-made one
For those who don't wish to make a fuselage rotisserie, Jeff Bordelon makes and sells one:
http://www.jeffsrv-7a.com/
brian
Brian Meyette, Cornish, NH
1995 RV-6A - N16RK (Ralph Koger) SOLD
RV-7A - incomplete, supercharged Subaru STi - N432MM - SOLD
2001 Quad City Challenger II LW - N28RT SOLD
www.meyette.us/RV-7Ahome.htm
03-30-2007, 01:36 PM
Thanks for the plug Brian, but I am no longer offering them. While nicer than most other options, they are far too labor intensive for me. However if someone wanted to pick one up from me directly and paint it themselves I might entertain that option.
-Jeff
