Old 09-15-2018, 09:59 PM
petehowell's Avatar
Default 2050 Hour Borescope
Daughter Megan was home from San Fran for the week and said she needed a pancake run this morning....so we went! On the way home, we tipped over 2050 hours and we did an oil change.
Compressions were 76/78/77/77 all cold. Lower plugs looked great!
The filter had some carbon in it and the screen was clear.
Here's your valve porn via the $11 camera on a wire - they look pretty good - sorry about the #4 Pic...
Pete
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
Old 09-16-2018, 01:05 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Excellent!
Pete, those look amazing. What oil/fuel/additives do you run? LOP? Ignition?
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 09-16-2018, 06:01 AM
turbo's Avatar
turbo turbo is offline
looks great. how are your wobble test specs at this time?
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 09-16-2018, 07:38 AM
flysrv10 flysrv10 is offline
Tell us about your $11 camera with a link to purchase one. Thanks.
Old 09-16-2018, 07:56 AM
crabandy crabandy is offline
Based on Pete’s photos and advice I purchased this little WIFI camera via Amazon Prime for $25.99. I liked the semi rigid flat cable because it has a smaller “footprint” going through the spark plug hole. To get the valve pics you have to bend the camera on top of the wire so it is looking up at the valves, it takes some manipulation while in the cylinder but gave me decent images of my valves. The WIFI feature is nice because it works with IPhone/windows computer/Android.
https://www.amazon.com/BlueFire-Semi...AIL&ref=plSrch
RV 7 400 hours and counting
19 donation done
Old 09-16-2018, 08:51 AM
Thanks for the link. I will look it up.
Old 09-16-2018, 10:19 AM
petehowell's Avatar
Default Answers
Hey Mickey,
Oil: Phillips 20W-50XC
Fuel: Mostly 92 Mogas - EtOH free, Some 100LL when Travelling
Additives: Fly early and often and.....Flamesuit on.... I use a bit of MMO in the Mogas. If nothing else, my fuel selector is well lubed.......
LOP: All but takeoff
Ignition: Dual PMags
Andy's Camera looks better than mine, for a few bux more.
Pete
St. Paul, MN
Old 09-16-2018, 12:18 PM
F1R F1R is offline
Default 150 HP O-320?
I am thinking this is a low compression 150 HP O320?
Old 09-16-2018, 12:41 PM
petehowell's Avatar
Default Compression
160 HP ECI Titan vintage 2006. Constant speed with MS Carb.
Pete
St. Paul, MN
Old 09-16-2018, 03:11 PM
rv8ch's Avatar
Default mogas
Originally Posted by petehowell View Post
Hey Mickey,
Thanks Pete - I assume you are running auto plugs?
Mickey Coggins
http://rv8.ch
"Hello, world!"
