The only reason I am aware that folks open up the oil door is to try to mitigate hot start issues. If your closing up shop, I see no reason not to button everything up.
By the way, I have used a thermocouple to check plenum temps and even after shut down, on a hot day, with a hot engine, temps stay reasonably cool.
Example - 104 F deg. OAT siting on a hot ramp, plenum temps peaked at 175 F deg.
For those with hot start issues, it is remarkable how much cooling can be had just by turning the aircraft into the wind, if you have any.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
