09-12-2018, 05:46 AM
Lower Intersection Fairing Fitting
So I have the 10 off the ground, and I've aligned and fitted the gear leg and intersections fairings. I have split the lower fairings so I can epoxy them to the wheel pants. Now to my question. Do I fill the leading edge of the intersection fairing with an epoxy/filler mixture to get a nice snug fit to the gear leg fairing, or does there need to be some gap in there to account for flex when the weight of the plane is on the gear?
As always, many thanks,
Lynn
RV-10 in Process
09-12-2018, 06:23 AM
Most people go for a snug gap. Among other things, that helps the gear leg fairings remain aligned.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
09-12-2018, 07:16 AM
Thanks, maybe I should ask if there is a problem if it is to firmly fitted against the gear leg fairing, just wondering when landing how much all of this flexes.
RV-10 in Process
09-12-2018, 07:52 AM
I should have worded my response better. A snug (contact) fit is what you want. Wear at the contact point has never been an issue.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
09-12-2018, 05:11 PM
The fit should be more snug than what is showing in your picture. There should be a small amount of room for paint and minimal movement. If you tape the gear leg fairing with 3-4 layers of PVC electrical tape, coated with mold release (car wax), then schmutz the fairing with an epoxy-flox mixture about the consistency of peanut butter (dry) and clamp/ clecoe it in place to cure, it should work well. Make sure the inside of the intersection fairing is ready to accept the epoxy - sand with 80 grit, and clean well - blow/vacuum any dust and wipe clean with isopropyl alcohol and let dry before applying the ? schmutz?.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
09-12-2018, 05:22 PM
hehe: ? schmutz? I like that. That was kind of the direction I was leaning, or layer glass on up higher to seal the top some. Thanks.
RV-10 in Process
09-13-2018, 07:48 AM
Here is what I recommend. Do not allow the intersection fairing contact the gear leg in the visible location you point to. It will just wear down. I spent hours on my bronze Lindy creating a 3/32 gap all way around with electrical tape. Inside the intersection fairings where you can’t see you can make it tighter if you want to use it to hold the gear leg fairing. My painter then thought he was doing me a favour by filling it in. Looked awesome when I picked it up. Flew home 2 hours with 2 landings and it looked terrible. These parts move. Redid it all and paid $1100 more for refinish and paint before Oshkosh.
I have a pic from a grand champion Pitts I’ll post tomorrow (pic on work computer)
Lynn
Visit and subscribe to Stu's Aircraft Factory on
https://www.youtube.com/channel/UCGQ..._as=subscriber
Steve "Stu"
Cold Lake, Alberta
7A #70015 - C-FZQX - built - sold
7A #71629 - C-FSIS - built - sold across Atlantic
7 #70215 - C-GOJU - flying - sold
7 #70703 - C-GMIY - flying - sold
6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
8 #82842 - C-FSBG - Fastback - built - sold
4 #2723 - building
09-13-2018, 12:04 PM
Pics
Here is what I aim for. The 2nd pics is prob a bit too tight for long term but the wear strip helps.
Steve "Stu"
Cold Lake, Alberta
4 #2723 - building
09-14-2018, 06:35 AM
Thanks Steve. Is that some Anti-chafe tape wrapped around the gear leg where the two meet? I was thinking that would probably be a good idea to put a strip on to keep it from wearing.
RV-10 in Process
09-15-2018, 06:19 PM
tape
Yup antichaff tape. Highly recommended around gear legs and firewall. Avail here and other vendors.
https://www.aircraftspruce.ca/pages/...ichafetape.php
Steve "Stu"
Cold Lake, Alberta
4 #2723 - building
