Keep VAF
Going
09-04-2018, 12:09 PM
Flyboy Access. pneumatic tailwheel pilot report
I recently installed the new Condor2 8" pneumatic tailwheel and fork produced by Flyboy Accessories, described here.
I have flown it a few times now and find it to be "most excellent"!
The fork looks very much like the Doug Bell fork. It is the same width (same axle bolts will work), but is a bit longer to account for the 1" of additional tire radius. No change to the steering link were required. The shiny aluminum split rim is very pretty and uses replaceable sealed bearings. The tire is the 200x50 (8.00-2) AeroClassic 6-ply with a 45?-stem tube, inflated to 50 psi.
Note: This size of tire and tube are used on many scooters, so non-aero, less robust versions are available very cheap. Maybe as a travel spare or if you operate exclusively on grass? You can even get foam-filled versions, but such might take a set with the kind of parked weight that is on the -8 tailwheel.
On the plane, the visual difference between the 8" pneumatic tailwheel and the 6" solid tailwheel is minimal. Over the 14' distance between the main gear and the tailwheel, the pitch change due the <1.5" net change in vertical at the tailwheel computes to about 1/2?. This is not really noticeable while taxiing or TO or landing. This will raise the step about 0.4", which is also not noticeable.
What is noticeable is the complete loss of the "banging aluminum drum" noise during all ground ops! Small surface cracks are completely absorbed by the tire, and larger cracks produce a "thump" instead "bang". I have had passengers ask "Is that OK?!"  during normal ground ops just because of the tailwheel-induced noise. It's pretty loud in the back seat, I think. That won't happen any more for sure. And when I smoothly and carefully (sic) lower the tailwheel after a wheel landing, now it smoothly and quietly kisses the ground.
Net result: I think this is a great improvement to the ground operations of the plane, especially on less-than-smooth surfaces and with a back-seater, at a cost of ~$400. FWIW,
Andy
Andy Elliott, CFI, RV-8, N303RV
Flight Reviews, Dynamic Prop Balancing
KFFZ, Mesa, AZ
2020 Dues Paid
09-04-2018, 01:06 PM
Thanks Andy, good review.
Is there a weight difference?
09-04-2018, 01:31 PM
Andy,
Thanks for the review.
Saw this pre-oshkosk and was wondering about it.
Would be great to stop the tailcone noise.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
09-04-2018, 02:11 PM
Good to hear this, as we have some good sized expansion joints on our taxiways. I've been wondering about whether this would help.
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
https://www.marksrv8.com
09-04-2018, 02:46 PM
Do you have any pictures of it?
My only concern with pneumatic tailwheels is that I have had a number of them pop on me.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
09-04-2018, 05:25 PM
Condor Fork and tyre picture
http://www.flyboyaccessories.com/product-p/1152.htm
I've been flying with a pneumatic tailwheel for a while but it's strange size and I can't find a tyre for it. Only place I could find one was Germany where it's used on a wheel chair!!
It does all Andy says though and the lack of 'banging' is sweet on the ears.
Think I might have to have one on my next visit to the US!
Regards, Clive
UK RV9
09-04-2018, 11:50 PM
Sorry, I did not weigh the fork/wheel/tire combination.  Subjectively, the wheel/tire combo seems lighter than the solid one I had, but total all-up delta can't be more than 1/4 lb.
I have never had a it happen in ~1500 hours of tailwheel flying, but worry about a blown tailwheel tire is not unreasonable, which is why I brought up the options for a cheap travel spare, including the foam filled tire version. Almost any FBO will have a 5.00-5 to sell you; not so the 200x50. These are available at any Walmart, however!
The 6-ply rated Aero Classic tire ought  to be sturdy. Guess we'll see!
Andy
KFFZ, Mesa, AZ
2020 Dues Paid
09-05-2018, 10:24 AM
Just keep it properly inflated at all times. That's the key. I've never blown a tail wheel in years of backcountry flying. (great, I just jinxed myself...)
Another good thing to bring along is a tire plug kit in case you puncture the tire. It's super easy to plug a hole, then use a bike pump (or similar) to pump up your tire. It'll work just fine until you can get home for a proper tire change. I've had to do it several times on jeeps and 4-wheelers out here in the middle of the desert, just not (yet) on a tailwheel.
Karl, Goodyear, Arizona (KGYR) ATP, CFII
RV-14A
Yak 50
=VAF= donor 2021
09-05-2018, 08:51 PM
Just received mine last week that I ordered at the show (Oshkosh) and like Andy said it's a nice looking high quality item. It will be a little wile before I can give y'all a flight report as I'am still putting the puzzle together. I don't believe that a plug type repair will work with this as it's a tube and unsealed split wheel/ rim old fashion bicycle tube patch kit would be the way to go.
Maule MXT-7(daily flyer)
Lancer 235(partner)
Raidial RV-8R Ephanage Done, Wings Done, Fuselage on it's tall Grove gear & engine hung
09-06-2018, 12:04 AM
Ok, thanks that's good to know!
RV-14A
Yak 50
=VAF= donor 2021
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
