Old 03-26-2007, 09:04 AM
phil9diesel phil9diesel is offline
Default Motor mount spacing
I'm building a motor mount. Where can you find the blueprint six hole spacing for the 9 series and what's the main gear angles, lengths, and diameter for holding the legs?
Old 03-26-2007, 09:45 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Suggestions
Buy a mount from Vans, cut off the parts you done want, add on the new parts.
Or see if you can borrow a mount from a local builder, and reverse engineer a jig from it.
Good luck, Mike
Old 03-26-2007, 10:32 AM
[quote=Mike S]Buy a mount from Vans, cut off the parts you done want, add on the new parts. Answ: Can't ....
Or see if you can borrow a mount from a local builder, and reverse engineer a jig from it. Answ: Don't...It's not for a Lycoming.
Old 03-26-2007, 03:36 PM
Mike S's Avatar
Senior Curmudgeon
Yep, I figured from your log in name that you were trying to fit a diesel to the plane.
You asked for firewall and landing gear specs, this is what I was referring to, that you could reverse engineer---------AKA-------copy from a borrowed mount.
Again, good luck.
Mike
