  #21
Old 09-04-2018, 05:59 PM
scsmith scsmith is offline
Originally Posted by BobTurner View Post
+1 good idea.
+2 on Bavafa's suggestion to try prying forward on the tank, gently. Yes, this is worth a try. My hunch would be that the stripped threads will not want to allow a clean thread to get started again, but it might. If it does, twice, you are home free.
If not, drilling the heads off the bolts is the best approach I can see. You can either remove a portion of the lower skin, or you could cut an additional inspection port in the skin directly where the bolt is. It is going to have to extend aft far enough for you to get an angle drill in there with a short drill.
When you are done, you will have to make a cover for the hole. You can copy the way the standard inspection ports are made so the cover is flush, or you could just lap a cover over the outside of the skin. No one is going to look under there, so it really only matters to you.
Wow, it is really hard to strip a plate nut! Or a AN bolt. I would be about as happy with that employee as I would be of the guy that drilled a hole in the skin of the Soyuz!
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 09-07-2018, 05:23 AM
mturnerb mturnerb is offline
Any updates on this one?
Turner Billingsley
RV-14A built/sold N14VB
RV-10 in progress as of May 2020
https://tbrv10.blogspot.com/
https://turnerb14a.blogspot.com/
Old 09-08-2018, 09:51 AM
Navy76 Navy76 is offline
I?ve only got room to work on one wing at a time. I?ve been working on the left wing and haven?t gotten back to trying to remove the right tank. I did call Van?s however and they recommended trying to put wooden wedges in between the inboard-most z-bracket and the spar to put some pressure on the bolt that is in the next outboard z-bracket. If that doesn?t work they recommended drilling out the bolts. While that might work for one of them the other is impossible to see and very difficult to even reach.
If it comes to drilling, I think I?ll return it to Vans and let them deal with it. It seems as though there is a high risk of damaging the spar and I don?t w,ant to take that risk for a problem caused by the factory.
I?ll updated this thread when I have more news.
Old 09-13-2018, 11:18 PM
I finally got the tank off. I ended up buying a tight fit 90 degree drill extension from ACS and then used a drill guide that I turned on my lathe to help me drill a #30 hole in the exact center of the cap screw head.
https://cvws.icloud-content.com/S/Ac...TQ-vnNYB1luBg0
Once that was done, I held the head with an ignition wrench to keep it from spinning and drilled it out to 3/16?.
https://cvws.icloud-content.com/S/AZ...f_tLtUgts3t28w
When the hole was deep enough, I held a flat bladed screw driver in the joint between the washer and the hex head and gave it a quick rap with a 6oz ball peen hammer and it snapped right off.
https://cvws.icloud-content.com/S/AS...mSlQFff8DIje20
Once I had the heads off of the cap screws, the tank was easily removed. One of the bolts came right out of the z-bracket when I grabbed it with a pair of vice grips and pulled back hard as I turned it to get it to re-engage the nutplate threads.
https://cvws.icloud-content.com/S/AQ...xfeq6mwoICMs6Q
Unfortunately, the other one wouldn?t re-engage no matter how hard I pulled so I?ll have to replace the nut plate.
https://cvws.icloud-content.com/S/AX...vQBhp1pjTAEPI0
It ended up not being nearly as hard as I thought it would be but I never would?ve been able to do it without the right angle drill and my homemade centering drill block.
Thanks to everyone who offer help and advice. I truly appreciate it. Sorry if the photos didn?t turn out, it?s the first time I?ve tried inserting photos here.
Old 09-13-2018, 11:24 PM
RV7A Flyer's Avatar
So to follow up...how'd they end up all boogered up in the first place? Were they too long or something like that (thus screwing in past the threads)? Something else?
Just curious to know how that happened to begin with, as I'm sure many are (to avoid a similar problem).
TIA!
BTW, that's really good craftsmanship to get that done so cleanly...well done!
2019 Dues paid!
Old 09-13-2018, 11:52 PM
As far as I can tell, they were simply over tightened and stripped. They appear to be the right length and size. I suppose they might have come from a bad bunch of stock but outwardly the look fine.
I intend to take a real close look at the nutplate to make sure they?re not damaged. I am also going to replace all of the tank fasteners just in case there was a quality issue with the fasteners.
Lyn
Old 09-14-2018, 07:13 AM
woxofswa woxofswa is offline
Might be related.
During my build, I came across a nutplate that just didn?t feel right as I was trying to insert a fastener. Upon closer inspection, I discovered that the nutplate had never been threaded. The sidewalls of where the threads would be were solid material as if that step in the manufacturing process had been skipped. Over the remaining course of the build, I would carefully inspect each nutplate for proper threads prior to installing it and sure enough, I came across a couple more of varying sizes. I imagine that forcing a fastener into a nutplate that had never been properly threaded could mugger it up pretty good.
Myron Nelson
Mesa, AZ
RV-10 N24EV
KITPLANES Contributing Editor
Old 09-14-2018, 05:09 PM
RV7A Flyer's Avatar
Lyn
That's gotta be hard to do, at least if you're tightening by hand. Those are AN-3s, right? So the torque should be IIRC 20-25 INCH-pounds.
Unless they were tightened with a power tool that was set wrong...?
2019 Dues paid!
